Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Double vision I have a 47 " panisonic projection tv mod # pt-47wx53g it is showing a double image in red. I tried to set the converge on my remote but the red would not line up. will this be an expensive fix? thanks for the help
  • Panasonic Master
  • 8,617 Answers
Its a repair you can do yourself for under 40.00 if you can solder . You need to replace both convergence ICs they are both STK392-110. You can get replacement ICs at the following link with free instalation instructions with pictures. TV shops generally charge between 400 and 600.00 for this repair which takes about an hour.
Heres the link
Posted on Jul 19, 2008
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Tv is showing double vision with red being the second image
This is due to convergence out chips failure, replace convergence out ICs in TV to get converge picture.
If you are handy with electronics stuff repair and want to repair TV by yourself (soldering work is required) then let me know exact model number written at back of TV to provide you more technical info OR ask local tech to fix it.
Jan 07, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a 47" panisonic rear projection tv. the tv is blurry double vision. The red has shifted to the right. The left side of the screen had less double but as you scane to the right it gets worse
It sounds that TV got convergence out IC failure, please replace convergence out ICs (two in this TV) for correct picture.
Required ICs are available in Part Store.
Oct 21, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Double image the second showing in red PT 53TW53G
replace the convergence ic's or look for loose connections that should do the job
Dec 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Nov 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Ghost images on tv
Bod convergence IC's. Try doing a reset of the TV first by pressing and holding the ACTION and POWER buttons while the set is on. A CHK screen with diagnosis will come up in about 5 seconds. Once that happens release the buttons and shut the set off and then turn it back on. If problem still is there then convergence circuit problems need to be fixed.
Mar 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
152 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
