Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
How hard to replace ICs?
I have a philips 60pp9202, i know its ic is bad. What would i need and how hard is it to change it?
thanks in advance
  • 1 more comment
  • 25lgt Jul 18, 2008
    the convergence ICs
  • Jb Wilson
    Jb Wilson Jul 19, 2008
    i need to know in full how to pull the stk392020 out and replace it with a new convergance plug help please
  • pinoy_eagle May 11, 2010
    What IC do you need to change?
  • 52 Answers
Remove the 4 screws going through the IC's, unsolder the 18 pins each IC, take a small flat head screw drive place it between the heat sink and IC and pound gently until the IC breaks free, wiggle the IC's to make sure all pins are free and remove them.
Take rubbing alcohol and a Q-tip and clean where you need to resolder. "So you can see the pads better." Put heat sink compound on the heat sink, slide the IC's back in, secure them with the screws, solder the pin's making sure you don't blob pin to pin.
Posted on Jul 20, 2008
Changed ICs and SSM board but still bad convergence
Have you looked at the Green Picture tube to see if there is a convergence magnet that may have come off? Not sure if this model had them but it's worth looking into.
Feb 04, 2014 | Philips 60PP9202 60" Rear Projection...
My phillip tv has started showing a double picture
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 11, 2010 | Philips 60PP9202 60" Rear Projection...
Can't correct my red blue convergence manually or by using factory preset...the unit is 7 years old, is my picture tube bad?
You have bad convergence ICs. There are 2 ICs in the convergence circuit, one is for the Blue the other is for the Red. You can buy 2 ICs for under $40.00. Replacing these ICs require soldering and desoldering skills. Sometime, the resistors in the convergence circuit go bad also. Be very careful, there is a very high voltage in a CRT projection TV the voltage is over 30,000 volts.
Best of Luck
Sabre
Feb 23, 2010 | Philips 60PP9202 60" Rear Projection...
Screen not centered
did you check the 6.8 ohm 1watt resistors? There are 12 of them.
Oct 15, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60''
This is a convergence problem that is being effected by heat. If you can solder, you should be able to resolve this yourself. Please be aware that there are potentially dangerous high voltages present inside the set even when unplugged.
Look for the large black ICs attached to a heatsink that will be marked STKxxx. These are the convergence ICs. Try resoldering the pins on these ICs and report the results. If the resoldering does not resolve the problem, the ICs may need to be replaced.
Keep us posted,
Dan
Jan 12, 2009 | Philips 60PP9202 60" Rear Projection...
Bad color blue green bad pic tried adj covergence no luck
The problem is either poor solder connections on the convergence ICs ore defective ICs. If you can solder, you can fix this yourself. Be aware however, of dangerous high voltages that are present even with the set unplugged. The ICs are STK392-120s and should be attached to a large heatsink. Try resoldering the pins first. If that fails to resolve the problem, replace the ICs.
Dan
Dec 29, 2008 | Philips 60PP9202 60" Rear Projection...
Blue and Yellow lines showing up on the screen.
STKs cost no more then 19.00 each www.electronix.com they have them replace both ICs use 392-180s better ics 100 percent holdup rate. they are big black ICs retail on ics 55.00 each
Nov 30, 2008 | Philips 60PP9202 60" Rear Projection...
Projection tv philips model number 60pp9202/17f
that sounds like the classic symptom of the convrgence Ics needing to be replaced they are STK392-120 you can get both replacement ICs at the following link with free instalation instructions. here is the link.
http://servicemanuals.vstore.ca/
Jul 07, 2008 | Philips 60PP9202 60" Rear Projection...
Changing ics
make sure the tv is totally discharged, This should be done after being unplugged for 8 hours or you can physically discharge the capacitors.
As long as you know what to do to solder them back on, you shouldn't have anything else to worry about. If you have any questions, let me know otherwise a quick search online should give you complete instructions of how to put them on or you can ask me.
Jun 05, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
