Question about Canon IMAGERUNNER 6570 Copier
Canon pc-6RE copier
After the toner cartridge, the first copy has some smudges, the next a lot, after that the copies are almost completely black. I've tried 3 cartridges, so the problem must be somewhere else.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Check the drum for toner leaking, sounds like the drum blade.
the drum is a shiny cylinder inside the machine, open and and see if it has black rings
Posted on Jul 18, 2008
How do I prevent excess toner from spilling out of cartridge and affecting copies?
If you 'replaced' or refitted the original cartridge, then I would suggest that the toner cartridge has failed. If this is the case, please try a new one.
If the original has not done a fair (check manufacturers specification) number of prints, you may be able to ask for a replacement.
If this was a new cartridge, and printer uses separate drums and toner cartridges. Then it could be a faulty drum. Above replacement path could be tried.
Aug 01, 2015 | Sharp AL-1631 Laser Toner Cartridges
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
Black lines on copies and on drum
There are a few things you can do to troubleshoot this problem.
  1. Be sure you are using new, clean paper
  2. Clean the copier's paper rollers, the marks may result from a dirty roller mechanism.
  3. Clean the copier bed's glass plate, smudges manifest themselves in the final copies.
  4. Clear any excess toner that has spilled in the toner cartridge chamber. Remove the cartridge, set it aside, then clean the compartment.
  5. Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy
If all else fails, try turning down the darkness of the copies in the settings, this can occasionally lead to lines and marks.
Feb 28, 2011 | Brother MFC-8460N All-In-One Printer
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Dec 02, 2010 | Samsung ML 2010 Laser Printer
Very ''dirty'' copies, despite cleaning.Black lines and black smudges all over the copies. Copier (used) delivered to me 2 days ago, does toner need to settle perhaps?
I would guess you need a new toner cartridge. Improper toner distribution would not cause the problems you are describing.
Dec 24, 2009 | Office Equipment & Supplies
Black smudge on middle of each copy
defective toner cartridge. Replace it.
Please rate solution :)
May 26, 2009 | Office Equipment & Supplies
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Black smudges on copies
Hi, try to pull out complete process unit(cartridge) with toner box .You have cleaner(blue or green color) move this cleaner from right to left side 4 or 5 times.Note that cleaner MUST be in home position-right side when you finish.Check print.
If problem still persists, you must do following:take away small grey plastic cap on left side of cartridge,then push complete charge corona(part with cleaner on top of it) to left side just enough to lift right side of corona from cartridge.Pull out that corona and you can see drum and developer roller. Turn the gear on drum,and look for smudges on black developer roller.Try to clean smudges with brush or with dry cloth.Toner will again attract to that area,but regular.
Dec 11, 2007 | Kyocera Mita KM-1815 All-In-One Laser...
Printed pages look dirty
That black dust that fell out is the toner. When you shake a toner cartridge that shouldn't happen. It looks like you have a faulty toner cartidge and that need to be replaced! Now to make your printer prints cleanly and clearly after you replace the cartridge, you'll need to get someone to service the printer(the faulty toner cartridge more than likely spilled toner on your internal printer parts, cause the smudges). Sevicing would mainly entail, taking down the printer and removing any spilt toner! If you feel you are up to this, be cautious, because toner can be hazardous to your health if you accidentally breathe it in! hope this was helpful! regards babb
May 10, 2007 | Brother MFC-7820N Laser Printer
535 people viewed this question
old marine
old marine
