Question about Denon DP-300F Turntable
Belt fell off
Denon dp 300f...my turntable was running fast so I lifted off the plate and the belt was just sitting there...what does it go around to work...I have tried everything.
  • Sharon Vespa Jul 18, 2008
    can I get detailed information on where to place the belt under the turntable. Also, where should the gear for the needle be in relationship to the neutral position.
    Denon DP 300f...the belt has slipped of the drive underneath the plate. How do I reinstall it? I need major details. All images that I have seen so far are not clear.
    Genius:
  • 1,011 Answers
Dear Sir,
First, remove the platter. On the bottom of the platter you should find what appears to be a decorative ridge or rim. It may even have a black stain from the belt.
Put the belt onto this rim.
Next, pull the belt away from the platter enough so that you can see it from the top of the platter. From the top of the platter, stick your finger into the loop you have created and keep the belt stretched enough to be visible from above.
Don't pull it much farther than that or you will stretch the belt and make it unusable.
You should see a small pulley situated near to where the outside of the platter would be if it were installed.
Start re-installing the platter onto its centre pin but still keep it an inch or so away from actually sticking it onto its centre pin.
Loop the belt off your finger onto the small pulley. Then push the platter the rest of the way down.
Well, you should have two pulleys, one for the drive motor (the
small one), and one for the record plate (the large one). Other
than that, you will have to go to a local stereo repair shop for
the necessary assistance, or you could contact this place...
http://www.approvedaudioservice.com/
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 18, 2008
  • Denon Master
  • 19,396 Answers
    Genius:
  • 1,665 Answers
There are two main types of phonograph turntable drives still being manufactured today, the belt-drive and direct-drive systems; the names are based upon the type of motor system found in each.
In a belt drive turntable the motor is located under and to the side of the platter and is connected to the platter by an elastomeric belt.
The design of the belt drive turntable allows the use of a less expensive motor than the direct-drive turntable. Also, the elastomeric belt absorbs motor vibrations which would otherwise be picked up by the stylus.
Brand new Denon DP 300F turns extremely slowly.
The turntable should be under warranty still so contact the makers and they should sort it out. Any tampering with it could void any warranty so don't let any unathoriesed person touch it.
Dec 13, 2014 | Denon DP-300F Turntable
If like what you say the deck is brand new you should contact the service center. They will attend to the matter free of charge. Web address follows:
http://denon.custhelp.com/
Denon auto lp turntable -model dp=29f
Lift the rubber cover off- there should be an opening or two in the metal or plastic turntable platter. Rotate it slowly until you see the motor pulley sticking-up; use a nail file to gently pull the belt from the bottom of the turntable over the pulley. rotate slowly to verify and then put the rubber cover back on. Let me know how it goes. Thanks.
Aug 01, 2014 | Audio Players & Recorders
How to adjust dp-300f speed
Both the owner's and the service manuals for your turntable are available for download:
http://www.vinylengine.com/library/denon/dp-300f.shtml
You only need to register (free) with them.
May 28, 2014 | Denon DP-300F Turntable
Have a brand new Denon DP-300F turntable that worked fine for the first two recods. Now when I use it the records sound as if they are playing in slow motion. Could there be an issue with the belt eve
It could, but it could be caused by something stuck inside it, perhaps from the packing or some other bizarre thing connected with it being transported to your home.
Feb 27, 2014 | Audio Players & Recorders
Running VERY slowly
The thing to do is to check the belt first, then look at things like is there a build up of grease dirt anywhere. Clean up the platter make certain no grease or dirt is the works causing it to slow down.
See also that the motor that drives the belt can turn freely and very easy by hand.
Jan 25, 2014 | Denon DP-300F Turntable
New DP 300 f with uneven speed ?
then you need to turn the potmeter , but since it is new, return it...
Jan 13, 2014 | Denon DP-300F Turntable
In my DENON DP-300F tone arm don't come back after playing record. It just stays in the end of record? How can i fix it?
A lot of decks don't actually do that anyway. But if it previously did this then it's probably a mechanical problem. Removing the bottom of the turntable might show up the cause of the problem.
Dec 08, 2012 | Denon DP-300F Turntable
I have a Denon 300f that works fine but run a bit fast so the music sounds really off...anything I can do to slow it down?
I was putting the belt around the wrong part...it needed to go on the bottom of the turntable itself then be attached to the belt drive.
Jul 17, 2008 | Denon Audio Players & Recorders
Denon DP-300F Turntable Logo
453 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
