Question about Yamaha RX-V450 Receiver
Open Yamaha RX-V 550 remote control
I need to find a way to open my remote control of my Yamaha RXV 550. There is one screw under the battery case.
    New Friend:
Remove the small screw in the battery compartment then put the long edge of a kitchen knife in the groove & twist. The case will snap open at that point then work your way around until it parts. Clean the contacts inside with Isopropyl alcohol & that should solve your problem.
Posted on Mar 05, 2013
4 Suggested Answers
SOURCE: Yamaha RX-V800 Remote Control
Change the batteries
Posted on Nov 13, 2007
SOURCE: Use Yamaha Remote to Control Scientific Atlanta Explorer 8300
I want to know the same thing.
Posted on Jan 17, 2010
Grubhead
  • 5309 Answers
SOURCE: I have att an uverse remote that turns on my
You need to try other codes for Yamaha, as clearly the one you have put in the remote is incorrect, perhaps it was for an earlier model.
Posted on Mar 07, 2010
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
My rxv 1500 does not power on at all
open casing, check fuse in power circuits block
Jul 02, 2010 | Yamaha RX-V1500 Receiver
My Yamaha RXV-795 remote control started broadcasting constantly. I see the red led constantly on, it should be on only when pressing a button. Han can it be handled?
Has anything been spilt on it, if so take the batteries out, pop it apart and remove the rubber backside, and circuit board, wash them with a damp rag, (not detergent) and let dry, then reasemble.
Aug 11, 2009 | Yamaha RX-V795 Receiver
How to open remote control Sony RM-Y181
There should be small screws (usually phillips head) at either the top, bottom or both ends of the back of the remote. Unscrew those and pry loose. If not, they will be under the batteries, inside the battery cover.
I assume that's what you mean by open?
:D
Aug 10, 2009 | Televison & Video
How much for a digital board for my yamaha a/v rxv 420 ?.an expert check my a/v and tell me the problem is the digital board.
What concerns me is why do you need a digital board, which cost around $150 or so. I just repaired a rx-v620 that needed the volume and mode crols replaced. These controls affected mant aspects of the digital circuits opperation. Your 420 could have a similar fate. What is it doing?
Jul 17, 2009 | Yamaha RX-V420 Receiver
HARMONY 550 UNIVERSAL REMOTE
As far as I know you cannot, you will need it to be in the devices list online, or find somebody with the remote to program it.
You should also be able to get the company.. Yamaha to send you the codes or send them directly to Logitech to get them added to the database.
Aug 25, 2008 | Logitech Harmony 550 Remote Control
Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Jan 08, 2008 | JVC AV-27230 27" TV
Openning the Yamaha RAV -206 remote
hey hows it going i also have the same remote.
what youll need is a #4 (small) and remove the two samll screws under the battery's. also you will need a small screw driver (flat head) it would be better if you have two.
what youll need to do is start in thecenter of the remote and slide the screw driver down the side of the remote keep one screw driver in as you slide and pry the remote apart. there are four latch's on the remote on each side (three along remote bottom center and top)
also on each side of the infared light that should be it just repeat the process on the both side and u should be good.
Cullen
Oct 27, 2007 | Yamaha RAV-2000 LCD Touchscreen Remote...
Yamaha RX-V450 Receiver Logo
1,293 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
