Question about RCA F32450 32" TV
Rca 32flascreen tv
Tv was working fine it is three year old one morning i was watching the show the picture and sound went of but a chirping sound in coming. I check the fuse it is ok now i would like to know what else i could check to remady the problem.
thanks
syed
sshaider1@hotmail.com
    Champion:
  • 317 Answers
High volatge transformer shorted...or component in hi E.
Posted on Aug 14, 2008
Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Jan 29, 2011 | Toymax Viore 42 in. Plasma TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
RCA 32 in TV no picture no sound just a beeping noise TV power is on
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | RCA HD52W59 HDTV Projection Television
CAN IT BE FIX?
Sounds like a bad horizontal transistor and flyback transformer . Do you know how to unsolder and or solder ? If so you might have a chance . If no the avg. to get repaired is around $90.00 to $130.00 so shop around as some shops will charge more . The parts you could buy your self for around $30.00 to 40.00 . Good luck and if you think you could fix let me know and see if i can get you part numbers .
Mar 15, 2008 | RCA 32V524T TV
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
Rca 36" F36685
YX2 = part # 244247..................................................T.
Jan 15, 2008 | RCA F36685 36" TV
F36650
Bad flyback transformer = 257805 or Asti 2078..........T.
Please rate this solution.................
Nov 05, 2007 | RCA F36650 36" TV
Tv WENT OUT
Picture tube failure is rare problem. Your problem is powersupply failure and short circuit in deflection area. This is quite common problem. My sugestion is before you got this problem picture clarity and color clarity is better perfomance in your satisfaction means repair is better. Otherwise replace it.
Sep 10, 2007 | RCA 24V511T 24" TV
Tv went dead while viewing, will not power back up
You have a short somewhere in the load for the power supply. Probably the horizontal output transistor and the flyback transformer. You need to have it checked out by a tech. You may want to get an estimate. Stargazer
Mar 11, 2007 | RCA F36715 36" TV
RCA F32450 32" TV Logo
75 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
