Fridge Freezer errors COOLING Dust on the condenser coils can cause overheating, observe safety precautions then clean coils. Switch off the unit before you clean them. If the problem persists, test the compressor for overheating. Overheating will cause many problems with cooling ability. Leave the unit unplugged for 3 hours and plug it in again. If it starts working, the compressor is probably overheating (Observe cautions with food going bad). A simple cause of the problem might also be that there is not enough airflow Lack of airflow is the number one cause of compressor problems and thus an owner purchasing another unit for hundreds of dollars when you can fix it for free.There should be at least several inches distance between the sides and walls/cupboards/ceiling. Electrical There is an in-line fuse mounted in the line supplying the power to the ice-maker. It is in the wire clipped to the side, change out this fuse asap. It is actually a 20-amp fused, associated with the grounded electrical supply. PARTS You may order parts very cheap from here www.canadianappliance.ca/KBRS22KV.html TIME TO CHANGE YOUR FILTER While your on the back of the system, please check the filter. There is a filter in the back of the fridge in the upper right hand side. If you do not change it, it will slow down the frig and burn it out permanently.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
