Question about Cameras
I have a Kodak Easy Share M1033. I turned it on the lens extended but now the camera's stuck. I can't turn the camera off at all.
  • Anonymous Dec 14, 2008
    can't reset Kodak M 1033
Try the Kodak Easy Share web site and look for trouble shooting FAQ'a or even an on-line forum.
You also might e-mailing or calling their tech support.
Posted on Jul 18, 2008
I dropped my easy share camera and now the lens is stuck and it will not turn on
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 12, 2011 | Kodak EasyShare M1033 Digital Camera
I cannot change the date on my camera Kodak Easy Share Digital Camera M1033
Press MENU, use left/right to highlight Setup, use up/down to select Date&Time.
You can view/download the user guide at
http://support.en.kodak.com/app/answers/detail/a_id/18915/kw/m1033/selected/true
Sep 08, 2010 | Kodak EasyShare M1033 Digital Camera
Kodak m1033 lenses stuck 'open'. Camera won't power on, just beeps and turns off when powered on. Camera froze when zoomed out max, removed batteries and now camera is stuck.
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Jul 14, 2010 | Kodak EasyShare M1033 Digital Camera
Camera turns on, and then turns off again right away
My M1033 had the same problem...I found a blog about someone using air to clean around the lens area...I cleaned my lens very thoroughly and noticed some gunk and once I cleaned this off, the camera seems to work like new!
Apr 05, 2010 | Kodak EasyShare M1033 Digital Camera
My kodak easy share m1033 camera turns off when i press any button
there is dirt or sand in motorized lens turn camera on and pop battery out before lens goes back in. Use a lens cleaning cloth and wipe all the outside of the camera lens well I also use a can of air and blew the three rings of the lens.I had to do this two times but now the camera works great
Mar 23, 2010 | Kodak EasyShare M1033 Digital Camera
My lens focuses only intermittenly
If you have the settings on AUTO the camera will automatically adjust to what it thinks will make the best picture.
Try and use the SCN.
You can also switch the flash on and off as you wish.
For more tips and tricks on picture taking please follow this link:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=38/13915/39&pq-locale=en_US
Jan 02, 2010 | Kodak EasyShare M1033 Digital Camera
When battery is put in red led in front turns on but lens will not extend or turn on it is an kodak easy share c763
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Aug 24, 2009 | Kodak EasyShare C763 Digital Camera
Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 17, 2009 | Kodak EasyShare One Digital Camera
My KODAK EASYSHARE M1033's lens will not extend.
your lense isnt extending because u need to charge your battery i gaurentee as soon as u let it charge it will extend once again
Jan 20, 2009 | Kodak EasyShare M1033 Digital Camera ...
Cameras Logo
222 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
