Question about Acer Computers & Internet
I want to erase my whole system and start fresh like when it came new i dont remember the buttons to push at start up
  • 38 Answers
See if you want to reset your PC to as it came new you will have to format your hard disk and install a fresh copy of the OS you use. For that you need a bootable setup CD. (most of the OS setup CD's are bootable now a days)
You must be having a OS cd like Windows XP, or Windows Vista or whatever you use.
Now what you have to do first is check you first boot device or boot order. For that you need to get into BIOS. To get into BIOS you will have to press buttons like DEL, F1, F2, F9 or F10. Don't press all together try one at a time. For most of PC's DEL works.
Now when you have got into your BIOS check for Boot order and see if CD/DVD drive has the first preference or not. Then Insert the disk into drive and restart your PC. Your OS CD will get booted and then just follow the instructions as the setup runs.
Before you format your PC be sure you have all the hardware drivers.
If you need some more help I am there.
Posted on Jul 18, 2008
  • 981 Answers
Just restore from the disk you got with it or the backup you made at first, or look up the buttons to press at first in your Acer manual.  You'll have to go forwards eventually, though....
    Problem Solver:
  • 63 Answers
  • 807 Answers
Contact Acer via their website, they are usually pretty helpful.
Lost my manual for toro 418ze snow blower. cant remember how to start it
The gas is bad. You have to add preservatives to it before you store it. Now you need to drain the sour gas and put in new gas. Then try to start it again.
Feb 06, 2015 | Toro Power Clear 418ZE - 38282
How to completely erase the hd
A hard drive is the brain of a computer. However, over time, that brain can become overworked and overly saturated with old software and outdated information. It becomes clogged and needs a fresh start. By erasing a hard drive, you can give your PC that fresh new beginning. With a few steps you can erase your hard drive manually, without the aid of expensive software.
Make sure your data is protected before you proceed. Whatever you do not save will be lost once you erase the drive. Use a CD or jumpdrive to save your information. Boot with a system disk. Before you continue to erase the hard drive, use the system to create a system disk. Use a 3-1/2 inch floppy disk and format it with the command "format a: /s"; this will create a bootable disk that contains system commands. Place it in the drive of your system and turn it off, then back on. Reformat the hard drive. Once you've booted with the system disk, type "format c: /s"; this will reformat the hard disk, virtually destroying the old hard drive you used to know. Depending on the of the drive, the formatting may take a fairly long time. Once the formatting is over, use the command "fdisk" to create partitions (which are logical sections for your hard drive's storage). Given the newer hard drives and operating systems of today, you can fdisk the drive and use all of the space. or if you dont have a floppy drive Download a disk wiping utility, such as Darik's Boot and Nuke (DBAN) or KillDisk. DBAN is an open-source product, while KillDisk is available as a free, closed-source download. http://www.dban.org/ http://www.killdisk.com/ Once you download the file, save it to your computer somewhere easy to remember. Insert a blank CD into your computer and use a CD writing program to burn the hard disk wipe utility to the blank CD. If you are using Windows Vista or 7, there is a built-in utility that will perform this task. Back up the data on your computer that you want to save, if necessary. Insert the CD that you created into the computer that is attached to the hard drive you wish to erase. Power on the computer and choose the setup option to boot from the CD. Once you have booted from the CD, you will enter into the hard disk wipe utility. Depending on which utility you chose to use, this screen will vary, but the choice you want to select is to erase or wipe a disk drive. Choose the hard disk that you wish to wipe and confirm that you wish to permanently erase the data on it. Before confirming this, you may wish to physically double check and ensure that you are erasing the correct drive. Once you start the erasing process, it cannot be halted, paused or reversed. You will have to wait for anywhere from a few hours to even a few days for the process to complete, depending on how large your hard drive is.
or you could just reinstall another operating system this will automatically delete the old wrong one you installed.
Hope this helps.
Jan 02, 2013 | Western Digital WD Scorpio Blue WD5000BEVT...
We dont have a manual for our Saeco Magic comfort coffee machine and the declcify message is up on the screen. What do we do?
Hi
Enter the menu by pressing the menu button. Scroll down until you reach “water hardness” and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to “Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process andwhen it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to “reset descale”, push the enter button and chose “Yes” and push the enter button. Now it will tell you we next to be descaled.
Apr 20, 2010 | Saeco Magic Comfort 103467 Espresso...
Two codes open door
You must hold that red button in for 6 seconds to erase the memory. Just remember you will have to program your hand remotes plus the wireless keypad.
Aug 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
MY 4GB Zune wont come on or charde
i would reinstall the whole zune software and make sure everything is freshly downloaded, and you computer should recongnize it, finally click on erase all content and your zune will reboot and be fine once more and work agian
please remember to save all your music before uninstalling the zune software
Apr 05, 2009 | Microsoft Zune JS8-00001 Digital Media...
How do i log on if ive forgotten my password
i) i you running your system on XP try to press or tap F8 or F10 or Del button on keyboard continously when you start your system(strictly) and you will get some option click Safe Mode option and you will get account Administrator(dont type anythingon it just click arrow beside it) and you will loginto
or u will directly loged in to your system with anything like Administrator account.........
ii) when you are loged on to your system , go to user accounts by clicking start button ---->control panel---->click on user accounts----->click on ur account and click deletepassword and u will not be asked to enter any password and succesfully u can remove your account
iii) now create a new or fresh account and keep password(and now remember password..........)
iv) but if you OS is Vista then you will hard time, since there is no option as such you reload your OS or reload OS freshly or load you Vista by using Vista CD...
Thanking you
M. Sridhar
Dec 29, 2008 | ASUS Eee PC 1000H Laptop
Is there a button to push that will erase my settings, contacts so it looks like new?
No but you can go into your settings and do a master reset, that will get rid of everything and put back like it was fresh out of the package.
Dec 18, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Restarting
1. Remove the battery.
2. Press start (red) button.
3. Insert the battery while pressing the start button.
4. Follow the instructions on the screen.
Remember to perform hotsync to back up your existing data since this will erase all data on your unit.
Jul 31, 2008 | Palm Treo 755p Smartphone
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
