When i turn my a/c on it makes a *tink* noise but the fan still works ((its not cold))
  • Anonymous Apr 11, 2009
    My home air conditioning will not come on. I do not hear any noise (no humming sound at all). What should I do. I changed the filter, but I don't know what else to do.
    An expert whose answer gotĀ voted for 100 times.
  • 67 Answers
The fan runs but there's no cold air? Is the air conditioner completely dead? See section 1. Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
The air is cool but doesn't seem cold enough If the air doesn't seem cool enough it is necessary to use a thermometer to check the difference in temperature between the air going into the unit and the air being blown into the room. Ideally, the temperature difference should be more than 15 degrees. For example, if the temperature going into the air conditioner is 80 degrees, the temperature coming out of the unit should be at least 65 degrees or less. If the difference is 15 degrees or more there is probably no cause for concern. If the temperature difference is less than 15 degrees you should check the following:
  • Air damper
Check to make sure the air damper is closed. If it's open, it will bring in outside air and reduce the efficiency of the unit.
  • Back cover
During the winter season many people cover their air conditioners to protect the unit from the weather. In the spring or summer they will sometimes forget to remove the cover. If your unit has a cover on the outside portion of the air conditioner remove the cover first.
  • Condensing coils
The condensing coils will always be on the "warm" side of the air conditioner. That is, on the side that faces outside of the room to be cooled. Air is drawn into the back of the air conditioner on the sides through vent slots and is blown directly out through the condenser coils. If the coils get clogged with lint, dust and dirt the cooling system cannot provide the cooling necessary. To clean the coils it will be necessary to remove the entire cover of the air conditioner or pull it out of the wall to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condensate water will be picked up by the condensing fan slinger properly.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
The steering is tight when cold and also makes noise until it warms up
try to change your oil for a syntec it could be helpful if you still have the same problem well tink to change your pump or try to check the pressure on your rack'n pinion.
good luck
Feb 21, 2015 | 2004 Hyundai Elantra
Why is my landrover making a ticking noise?
Where is the Tinking coming from? If Wheel Area, Remove the Wheel Hub Cap and check for small Gravel,
Also is this tinking sound only when making right or left turn? Could be C/V Axle.
Need more information.
Sep 10, 2012 | 2000 Land Rover Discovery
Ticking noises / Spun Bearing
If it is a light ticking noise it could be something as simple as tappits on rocker arms. valves pinging..........IF it is a ticking and not a KNOCKING noise then i would have another mechanic take a look at it...Sad thing that happens is some mechanics will give wrong suggestion for the simple fact of making your wallet lighter.... not saying this is the caes but something this costly needs more than one mechanics opinion. My suggestion would be have another mechanic look at it not telling what the first mechanics opinion was and then see how they compare..... hope this info helps and good luck....Please rate my post.
Aug 16, 2012 | 2007 Jeep Wrangler 3.8
Have 2002 996 and when I turn off the engine there's a metal clacking sound. Bought the car at 24,000, had a full buyers inspection, warranty inspection and nothing was ever mentioned about it. What do you...
it sounds like your catalitic converters could be cloged, but also exaust sytems do make like a tink tink tink sound cause well, heat causes metal and most things to exspand and when the cool down really fast the contract and will make a litle tink sound.
Jan 29, 2011 | 2002 Porsche 911
2000z71 1500 stuck in 4 high and makes loud tink on tight turns
The electrical wire came loose from the back of my 2H, had to take the panel off and re-soder it. Works fine now.
Apr 27, 2010 | 2000 Chevrolet Silverado 1500
My 2009 cobalt makes a clicking noise everytime I turn the car off. What is causing this noise?
the cobalts have a very thin walled exhaust and also have a heat shield wraped muffler, the clicking noise you are refering to im guessing is more of a "tink" noise? if it is, its the exhaust cooling down and contracting
Dec 18, 2009 | 2009 Chevrolet Cobalt
My 97 outback has a terrible noise
Not really sure what "tinking" is, but if it only makes the noise while moving, it's either brakes or CV joints.
Sep 23, 2009 | 1997 Subaru Outback
Kia Rio - Heater not working fan works but noise coming from fan.
open glove box and make sure that none of the papers from that can get down to blower motor
Jan 17, 2009 | 1998 GMC Sierra
Heating & Cooling Logo
221 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
