Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Not clogged, dirt emptied, but gets hot and shuts off
This vacuum usually shuts off when the cylinder gets too full of dirt... then I empty the cylinder and it starts up again. But lately, it won't start after I empty the dirt. It feels very hot around the motor, and I have to let it sit 5 or 10 minutes before it will start. Then it only runs a few minutes before shutting down again. I checked all the tubes, cleared out hair from the brushes, washed and dried the sponge filter, but same problem. I even took out and looked at the "permanent filter" which looked pretty dirty but didn't know how or if I should try to clean it. Help! Thanks, Cyndi
  • 372 Answers
Hi Cyndi.
Try this site for help has it service manuals, http://dysonmanuals.llc.nu/
Posted on Jul 21, 2008
Where is the fuse located on a dirt buster vacuum cleaner?
Black & Decker Dirtbuster Vacuum Cleaner
no fuses in these ....double insulated
the motor has a thermal protection shut off when overheating
will start again when cooled down
empty bag often
if unit keeps shutting down replace vacuum
2477301-black-and-decker-dirtbuster-vacuum-cleaner-0-bwbjq1d2inqbxh534mfqkm1n-3-0.jpg
Apr 29, 2017 | Vacuums
Blows the dirt back out even when empty.
If it is blowing dirt out that usually indicates a clog or obstruction somewhere. You'll have to follow the airflow from the floor to find where the clog is at.
Mar 28, 2016 | Vacuums
Lately as I'm vacuuming, my vacuum will turn off. I can start it again, and it will shut off again. It seems like a power issue. Happens different places in the home, so it is not the outlet.
Some vacs shut off when the dirt bag is full Check your brush area and see if there is dirt or bits of string like things wrapped around the brush or the brush ends. This will cause the machine to shut down as well if there is pressure holding the brushes. Will it run if you wiggle the plug if so you could have a bad plug as well.
Jul 07, 2015 | Kenmore Vacuums
My vacuum just stopped while I was vacuuming. It's a 6300 and I purchased it 2 months ago.
Some vacuums have a shutoff switch for then the dirt container gets full. Check that first. Empty or replace as needed and see if it runs again.
If it's still dead, take it back...
Jun 12, 2015 | Vacuums
Do my Dirt Devil have a restart button it just stop running
Hi! No the vacuum doesn't have a restart button, but it does have a thermal protector that will shut the vacuum down when it is overheated. If your dirt cup was too full this will activate the thermal protector sensor. Clogs and dirty filters can cause this as well. We recommend emptying the dirt cup, tapping out the filter and checking the hose for clogs. The vacuum will come back on usually within 45 minutes to an hour. Hope this helps. If you need further assistance don't hesitate to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil
Sep 20, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Why vaccum not emptying
Hi! If no dirt is entering into the dirt cup it could be that you have a clog in your hose. Detach the hose from both ends and use a broom stick or something similar to carefully loosen and remove any clogs in the hose. Hope this helps! If not you can always reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil. Thanks!
Aug 29, 2014 | Dirt Devil Breeze Cyclonic Bagless Upright...
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
Dyson DC14 animal shut down, now won't turn on
This coul;d be a couple thing, it could be that the machine is full and shut off due to a heat sensor. You should see if it has a reset button on it for the power head. I don't think it does so I would empty it out and clean the filter and try it again. Also did you try it in another plug in as you may have blown the breaker.also if the dirt container is not in just right it will not turn on as threre is a safety switch so it can not be run without the dirt container. Try these things and if you have npo luck write back and we will try again.
Oct 08, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Every time I try to vacuum my apartment with my Dirt Devil Featherlite bagless vacuum, it shuts off before I have finished one or two rooms. I then have to wait 30 minutes before continuing. I had the...
your motor in the vacum is getting hot.Thats why it shuts off.Its fitted with a shut off switch to stop you doing any damage to it.1 The reason for getting to hot is that you are filling the cannister to full.Try emptying it half.good luck.
Jul 31, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
304 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
