I am buying a pioneer vsx-d414 receiver and want to no if it will drive my cerwin vega e-712 speakersv says for receivers rated 8ohms or lower.. , just currious
  • Anonymous Mar 31, 2014
    HOW DO YOU USE QUICK SETUP
    HOWN TO USE QUICK SETUP
    President:
  • 624 Answers
Yes the Pioneer will drive the Cerwin Vega speakers. The Pioneer requires at least 8 ohm speakers and if the Cerwin Vega speakers are 8 ohms, it won't be ******* the receiver.
The speakers you have are high wattage, so the Pioneer may not be able to get the most out of them, but it should be pretty good.
It is always good to have speakers rated at a higher wattage than the receiver, that way the receiver will not fry the speakers. No matter what the wattage of a speaker, it will not pull more power out of an amplifier than the amplifier is capable of delivering. Some people have a mis-conception that if a speaker is higher rated that it will blow up the amp, this is just not true. Speakers do not pull power from an amp, they only put out as much power as the amp is pushing into them. But you can blow up an amp by driving it too hard for too long of time. They just get too hot and the heat stresses the amp circuit after a while.
I hope this helps.
Dave
Posted on Jul 18, 2008
Hi, After using the VSX-712 with headphones the
Need to have the headphone jack replaced. One of the internal contacts is shorted. You may be able to temporarily correct the problem by inserting and removing the headphone plug a few times.
Sep 20, 2013 | Pioneer VSX-D712 Receiver
Display message "DSP NG"
Hi pay attention to do all interconnections right
You can get help dowlowding a low cost service manual at link below:
http://www.smpcshop.com/VSX-D414-VSX-D512-p-5216.html
Have a nice day and Good luck
Feb 21, 2008 | Pioneer VSX-D511 Receiver
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
Overloads with volume a third od the way up,i have 2 12 inch cerwin vegas hooked to it
fan_of_tony,
There is not much info in your question to properly answer it but here are a few things.
1) The VSX-D307 is a home receiver that is rated for no less than a 4 ohm load. If you have two 12" 4 ohm CV subs on the same channel and they are in parallel, that would create a 1.7 ohm load which would easily cause the problem.
2) If you have one on each channel connected along with speakers that are for you mids and highs, the way they are connected could be reducing the resistance load the amp will see which would easily cause the problem.
3) If you have one on each channel and no other speakers the problem would be simply that your speakers can use more power than the amp can produce. Thus you are able to raise the volume of the amp passed it's maximum output which would cause the amp to clip and the amp will go into overload protection.
4) Your receiver has an 8 ohm rated amp. Which means it can run at 4 ohms but the amp will produce more power at lower volumes on the knob setting and will max out at lower levels than if you were using a 8 ohm speakers.
In short, CV's can use a lot of power and your receiver, regardless of advertised power levels, cannot give the speakers what you are looking for in sound levels. Buy a larger dedicated amp for the CV's as the clipping from your Pioneer receiver is doing damage to your CV's. Your speaker's can hear the clipping before your ears can so damage will start to occur before your ears can hear the clipping.
-Chris
Jan 20, 2010 | Pioneer VSX-D307 Receiver
Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
Feb 10, 2009 | Pioneer VSX-D506S Receiver
Poping sound coming from pioneer amp
whitrashtruk,
Your M-91 has a 8 ohm rated amp. Your CV's are 4 ohm speakers. When your reduce the resistance the amp see's it requires the amp to work harder and will max out at much lower volume knob levels.
Simply put, you have big speakers that require big power. You receiver is not capable of providing the big power you need and will only cause damage to your speakers and receiver.
Buy a larger dedicated amp for your speakers as you will never hear the full potential of your CV's from any receiver. Both great components; just not a good match for each other.
-Chris
Dec 30, 2008 | Pioneer Elite VSX-91TXH
Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Mar 24, 2008 | Audio Players & Recorders
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
 Grubhead
Grubhead
