Samsung pcj522r Had the blue crt convergance done and was looking good and after a while then the blue went out and it will come on and off and flicker from time to time, have any ideas?
  • Ken Jul 18, 2008
    Found that the wire running from it did not have good contact on the main board.
  • 8,617 Answers
Check the Blue CRT pcb for solder cracks especially around the tube socket
Posted on Jul 18, 2008
My Samsung 52" Older Big Screen went out. When I plug it in, it makes a funny sound like it's trying to come on then starts clicking sounds like a cricket noise. any ideas??? model pcj522r
The convergence is dead.It cause 3D colors misalign
and clicking chirping noise with no power on.Know how how to solders?The 2 Convergence ICS must change and all it resistors. Tries Tv Repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The shop will cost $300 for parts and labors.
Feb 07, 2010 | Samsung PCJ522R 52" Rear Projection...
Samsung pcj522r
no but the board which is on the upper neck of the green CRT could its the velocity board which has an effect on all 3 tubes convergence.
Jul 20, 2008 | Televison & Video
Samsung pcj522r
Not really, its possible that the Convergence yoke rings may have gotten misaligned when installing them onto the replacement Tube. Usually you need to realign when installing a new tube.
Jul 16, 2008 | Televison & Video
No blue manual convergence - Samsung pcj522r
Thats a very strong possibilty the phosphorus may be burned off the CRT face. Does the blue project when powerd up and looking in from the raer of the set? Look into the blue CRT lens while its playing If you can see a clear picture I would think that you have some open resistors in the blue circuit, If you cant see a picture its time for a CRT. If you need a CRT let me Know I have a good source for them Used.
Jun 21, 2008 | Televison & Video
No blue convergance
need to replace the convergence ICs. If you need a link to get replacement ICs let me know.
Jun 07, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung pcj522r shuts off randomly
samsungs have convergence ic that heat up and cause tv to shut off but most of the time the colors will be off. Alsp solder connections could cause this on voltage regulators.my guess would be convergence ics cost for repair is 250.00
thanks doctor video
May 12, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung PCJ522R Pictures is completely shaded with yellow
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to www.vancebaldwin.com or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Oct 25, 2007 | Samsung PCJ522R 52" Rear Projection...
Samsung PCJ-522R
hey john if you look into the blue crt it will be very foggy..the coolant in the crt needs changing. you may want to contact a local tv repair person for more advice and coolant changing procedures....john
Sep 01, 2007 | Samsung PCJ522R 52" Rear Projection...
Blue lens works, but has a weak projection compared to the green and red lens
The most common problem I have seen with these Samsung projo units is the blue CRT (picture tube) failing. They usually form algae on the face of the CRT which means replacement of the CRT or rebuilding it by a CRT rebuilding company. I wouldn't suggest the novice to pull the CRT out because if the wrong mouting screws are pulled you will spill out the cooling fluid within the face of the CRT and that will cause more problems.
Apr 18, 2007 | Samsung PCJ522R 52" Rear Projection...
Problem with Samsung PCJ522R 52": White is yellowish
It is possible that you may have had a leak in one or more of your CRT coolant chambers, see: Product: Projection TV Bulletin # PJT01-001 Model: PCJ, PCK and HCJ series Bulletin Date: 6/1/01 SUBJECT: CRT Leakage Background: When repairing set for CRT leakage, check if CRT has Expansion Chamber installed. If not, install Expansion Chamber on all 3 CRTs. Production during November 1999 ~ September 2000 will need Expansion Chamber installed. Rear panel will indicate production date. This can also leave a residue on your printed circuit board that would have to be cleaned off to prevent further corrosion and leakage currents. Hope this helps.
Feb 01, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
