Question about Onkyo Audio Players & Recorders
Onkyo HT-5500 Receiver goes into setup mode as soon as I plug it in. It will not go into stand by or any other mode. None of the buttons on the front work.
  • 624 Answers
This sounds like it has a microprocessor problem. Try unplugging it from the wall and leave it overnight. That will give the microprocessor a chance to reset and then try it again. If it continues to do the same thing, you need it serviced by a professional technician. I am sad to say, there are no easy fixes for a microprocessor problem.
Onkyo receivers are very good quality and are normally worth getting repaired. If it were junk I would tell you to just buy a new one. But even the very best equipment can fail. I have been repairing audio equipment for nearly 18 years and have never seen any brand that did not have some type of failures at some time or another. Onkyo's may not be the most expensive receivers, but they are some of the best engineered receivers I have worked on.
I hope this helps you decide what you are going to do, and hopefully after the micro is reset, it will work good again.
Let me know if you need any more help.
Posted on Jul 18, 2008
Only plays through one front speaker when in video mode.i've tried v-1 v-2 and v-3. i'm using optical for audio
Hi Richard, please make sure that the source has been assigned to the optical connection via the setup menu or you can select the source and then press the digital input button until the display shows the optical connection where the physical connection was made on the back of the Onkyo, Thanks, JT
Apr 01, 2015 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
When in video mode only plays through one front speaker
Hi Richard please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings., Thanks, JT
Apr 01, 2015 | Onkyo HT-R560 Receiver
We have "HT R670" and "HT R360" A/V Receivers with questions regarding Universal Remotes and Android Apps.
The Onkyo App will not work with the HT-R670. This receiver is part of the HT-S6200 Home Theater package and is not network compatible. You might be able to use the Logitech Harmony Hub and app or another remote control app paired with an IR repeater pointing at the receiver. Some universal remotes may support changing the inputs on the receiver. However, I don't know of any specific model that will work. The Logitech Harmony remotes are probably the most likely to support the Input button; it may take programming a specific button to match the receiver's Input function. If you need a replacement for the original remote, one source is . The manual for the HT-S6200 is available here: .
I can't find an Onkyo HT-R360 listed even as part of home theater system. There is an Onkyo HT-RC360. The manual for that is . While this model has a network connection, it is not compatible with the Onkyo app either.
I wish that I had better news for you.
Nov 11, 2017 | Audio Players & Recorders
Receiver display started scrolling fast through set-up options on it's own and then stopped scrolling with "V1 PLX Movie" in the display and none of the front panel buttons including the power switch have...
Try this, but you'll lose any presets and setups.
To reset the AV receiver to its factory defaults, turn
it on and, while holding down the [VIDEO 1] button,
press the [STANDBY/ON] button. “Clear” will
appear on the display and the AV receiver will enter
Standby mode.
Jun 09, 2010 | Onkyo HT-S790 Home Theater System System
When power button turned on, receiver powers up
I have had the same problem with my new Onkyo HT-S 5305B (A/V Receiver + 5.1 speakers). To solve this, try to follow "Troubleshooting" guide that came with your system. I followed it 2-3 times. In my final attempt, when system was not shutting down but stayed-n with no sound, I played with the setup and tried changing audio adjustment, input, dimension etc. and slowly I was able to get speakers up one after the other. It's working fine now.
However, I am little concerned that why such a high-class Onkyo system failed in less than two days, forcing me to troubleshoot. - Apurva
May 10, 2010 | Onkyo TX-SR500 Receiver
No center speaker out put
Check the setting...
Advance to CENTER
Select the size of the center speaker:
Pressing the PRESET/MODE ADJ < / > buttons switches among LARGE, SMALL or NONE.
Dec 27, 2009 | Onkyo TX-DS575 Receiver
Every time I turn on my Onkyo receiver it goes in to protect mode.
Please check your speaker cables. Make sure that all of them are seated properly, none is touching each other or to the body of receiver.
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny frayed speaker cable touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough to activate and it could blow a few trasistors in the power output circuit.
Please take out all the speaker cables, unplug your receiver from the mains and try to restart without any cables plugged. If it powers on then you are lucky.
If not and the receiver still goes into protect mode or wont turn on then it possible that there are bad connections on the main board or have some blown transistors. How old is your system? if its still under warranty then you should contact Onkyo immidiately.
Let me know if I can be of any further help. Please do rate this solution and thanks for using FixYa!
Mar 08, 2009 | Onkyo TX-SV727 Receiver
Connecting Sirus audio to Onkyo HT-R500
Carl- If you are sending a Line Level Audio signal to your ONKYO RECEVER, from your Sirus RCA cable Output, IE, the CD input, the VCR input, the AUX in, ETC. No Need to have the RECEIVER in the FM mode, you are just needing amplificaton of the sound signal or Sirus signal sound.
Feb 28, 2009 | Onkyo HTR500 Receiver
Originally Posted by 3FingeredGlove viewpost.gif We can make this work. You didn't mention which setup code you're using, or explicitly say whether the OK/Select button is red or gray (the manual you're using is for gray), so these are somewhat generic instructions. Should work, though. This will provide a power toggle function to the Power key.
Use red numbers for the red OK/Select button remote, grey numbers for grey button remtoes.
Temporarily assign setup code 30842 or 0842 to AUX
1) Tap AUX
2) Press Setup until 2 blinks
3) Enter 30842 or 0842The remote should blink twice
Assign NEC1 IR protocol device 210, subdevice 108, function number 203 to Power (you don't need to understand these numbers)
1) Press Setup until 2 blinks
2) Enter 994 (2 blinks)
3) Tap Setup
4) Enter 00051
5) Tap Power (not All On)
Assign setup code 30135 or 0135 to AUX (this is NEC1, 210.109)
1) Tap AUX
3) Enter 30135 or 0135
Nov 15, 2007 | Onkyo HT-SR800 System
that is because i think that your reciever would have its own code
Jan 29, 2007 | Onkyo HT-S790S System
289 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
