Question about Kitchen Ranges
I am having trouble removing the oven door of my westinghouse oven model number pgl657w, i need it off as i am replacing it with a new oven door.the frame is all i need to remove as the glass broke. thanks shay
  • Anonymous Mar 29, 2014
    need to replace gasket around the glass in the oven door
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
Open the door about 2 iches and lift upward and the door should come off
Posted on Jul 18, 2008
How do I fix my Westinghouse Oven
Hello Leonard;
My name is Peter. I am a retired Sears field service appliance technician.
The fault codes start with a "F'. The Do may mean Oven Door.
When you close the oven door is it loose at the top and not completely close?
If this is the case you have a bad oven door lock assembly (Part number W10195934). The assembly has a micro switch which activates a 1/4 turn motor.
The part if ordered locally will cost you $108.00 plus tax. If this is the problem you can search the internet and probably get it for $70.00.
If you call a Sears service technician it would be $108.00 x 2 plus $140.00 labor.
To access the door lock assembly, you need to remove the oven wall restrainer strips, Pull the oven out about 4-5 inches.
Go into the following website plug in your model number to see your oven diagrams.
This is a common failure.
Good luck,h
Water Filters Lawn Garden Appliance Parts
Jan 29, 2016 | Ovens
Hi, We have a Westinghouse electric wall oven with a door which appears to have a broken spring inside. We have previously been able to set it back in gap for hinge but now it has given up holding...
You should be able to buy new springs or the hinge complete from most appliance parts outlets. On some Westinghouse, the door will slide straight off the hinges but on others, you have to strip the door to get at them. Try opening the door and see if the door slides up and away from the oven. If it does, its pretty easy to change the hinge, if not, there will be a little clip on each hinge which locks the arm in place. Slide the clip on both hinges to the front and then you can lift the door up and out of the oven. remove the screws holding the door together and then you will see the 2 screws which hold the hinges in. Order a left (or right) hand side whatever one you need, but I would suggest that they are replaced as a pair, otherwise the door may not close evenly.
Jul 31, 2011 | Ovens
I have a westinghouse fan forced 600 wall oven and I need the serial or model number to get a new door for it, Thanks
There is usually a small sticker on the oven inside the door at the bottom edge of the oven. This usually has the information you require on it. If this is not the case then if you have the handbook for the appliance you can get it from there.
Failing this take a digital photograph of it and this will often be enough for a parts supplier to identify the item.
You don't say how old the oven is but a new door will be quite expensive, check out the cost first relative to .the cost of a replacement oven.
Dec 11, 2010 | Ovens
Westinghouse POC700M Ultimate One wall oven. We are putting a new element in it. How many wires should connect to the element on either side (ie. looking into the oven left and right)?
if you have not removed the old one yet . reinstall the ones onthe right to the right. and the same on the left . there is on most ovens only two . mm
Nov 22, 2009 | Ovens
Bosch range front glass smashed
open the oven door and look on the sides where the door meets the oven. also slide open bottom drawer and look where drawer meets oven. hope this helps!
Aug 29, 2009 | Bosch HMB402 Microwave Oven
I need to find the model number for insurance purposes
Hi, The model # should be on the frame behind the bottom pan drawer door or on a label around the main on=ven door.
I hope this helps you. lease let me know if I can assist you further.
Vic
Jul 10, 2009 | Magic Chef 31000 Gas Kitchen Range
Westinghouse Built-In Oven Model OLR-24
Hi, Did you ever figure out how to do this? I am facing the same problem! Thanks, PaineChristopher@aol.com
Feb 10, 2008 | Kitchen Ranges
Removing and replacing door assembly
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Dec 08, 2007 | GE JVM1650 1000 Watts Microwave Oven
Kitchen Ranges Logo
702 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
