LG LCD TV -model 32LB9D
Satellite box hooked up in AV1, there is pic but no pic with DVD player hooked up in component 1 or 2. sound only.
5 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: "No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
Posted on Feb 08, 2007
That is the solution, thanks. Also in the video settings in your dvd player menu select which cables you used to hook up to the tv. Y Pb Pr
Posted on Oct 07, 2007
SOURCE: Westinghouse LVM-37w1
I have the same issue, and I have read about 1 more of thse I wonder if they have a issue where they all break this time of year :-) I WILL NEVER BUY A WESTINGHOUSE AGAIN
Posted on Dec 17, 2007
  • 70 Answers
SOURCE: how to connect my COmponents to my new LCD TV
Do you mean a Playstation 2? If so, buy a SCART to component converter (like a SCART plug but with yellow white and red inputs) Put it in one of the SCART sockets and plug in your PS2. Hope that helps...
Posted on Jan 27, 2008
  • 52 Answers
SOURCE: hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Posted on Mar 04, 2008
Have a video cassette recorder & dvd/cd player. Need instrucdtions on hooking it up correctly
power off all items... do you have cable/satellite (this cable wire needs to be connected from box to the in on VCR) from the out on VCR connect back to TV...okay DVD you should have 3 cable wires (red/white and yellow) this is to be plugged into AV1 (on the back or side of TV) follow the colors... red to red and so on...note you should tune your Flat panel CH 3 along with the VCR (set it CH 3)... okay turn on all, get a tape, pop it in VCR press play... do we have a picture and sound? okay press stop.. get a DVD disk place it into DVD player press play.. using your TV remote we need to change the source from component/cable to AV1 in order to view a DVD. and change it back once finish so you can view regular TV. okay do we have picture and sound?
have fun enjoy your movie
Aug 09, 2011 | Televison & Video
Have satelite as AV1, Wii as AV2 - hooked DVD player up as component 1 using RCA plugs but it is only black and white and very grainy.
Connect the yellow RCA jack, which is actually called composite video, not component, to the DVD. If it's component, it's the wrong jack and you'll need the additional 4 cables to satisfy a component connection for HDTV.
Dec 23, 2010 | LG 32LG30 32 in. LCD HDTV
I'm having trouble hooking up Toshiba DVD, HD cable box and TV.
first is this DVD recorder? its not okay plug the wires from DVD to tv (left / right and video -digital in or av1 in) cable box is connected to tv (red/blue/green) tv should be on component (source)...to view dvd switch to av1 or digtal1.......if this is a recorder get a coaxial cable and connect from cable box out to DVD in (the TV setup stays the same as above) DVD set up should be on CATV/ch 3..........the out connection is the same as a reg player (see above)
Aug 28, 2010 | Toshiba Televison & Video
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
Im trying to hook up my new lcd tv using a cable box and a dvd player but cant find any diagrams. As of now I can get a picture but the sound is low and can only be turned up by the cable remote. Any help...
it should not be a big deal red and white is sound yellow is video, if you have a converter box and are not getting a signal I would suggest you try moving your antene to get picture. Try hooking the DVD plaer into the TV to AUX 1 or AV1 or AV 2 Or AV3 and make sure the TV is on the right channel on to see Picture and correct level of sound, are you running anything threw a coverter box? Need to know the TV brand to do a diagram. The output from the DVD player shoud go into AV1 and the wire colors should be the same DVD output to AV1 input or AV2 in?
Jul 06, 2009 | Televison & Video
Panaonic Home Theatre DVD system only plays movies inblack white
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
Jul 06, 2009 | Audio Players & Recorders
Sound but no picture on TV
Try hooking your components up to the "AV1" and "AV2" jacks on the TV. I experienced this when hooking up my DVD and VCR (movies of my kids so kept it around). I hooked one to AV1 jacks and one to COMPONENT jacks and had the same result you're describing. Hope this helps.
Mar 28, 2009 | Philips Televison & Video
Hook up vcr
Keever
Mar 04, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
