Which system? PS3? You have the infamous YLOD, aka. Yellow
Light of Death. This is the number 1 cause of pS3's dying. It is an
overheating issue linked to your CPU and GPU (the processor chips)
You will need to find a local PS3 repair shop who can repair this. Do
not try to attempt repairs seen on the internet yourself as some
would suggest.You could make things much worse and render the unit
totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED* IS THERE A DISC STUCK INSIDE? If you have a unit that is not
backwards compatible, any non 60g or 80g then you can retrieve your
disc. Power off the unit using the toggle
switch on the back. Hold down the 'eject' button and turn the toggle
switch back from off to on. This will run a fan test and eject your
disc. Remember, this will only work on the 20, 40g models. Not the
backwards compatible units with the 4 usb port holes and the memory
card slots.
If so:
folloe these steps
camera<settings <Flash< turn it on . or camera<more<flash<turn it on
