Question about Bosch HGS442UC Gas Kitchen Range
Bosch HGS442UC Gas Oven won't light
Igniter activates and glows red for minutes. Gas does not turn on to burner. No sign of a t'couple close to igniter to cycle on gas valve. Range top works fine so natural gas connection is good. Only have install & operation manuals. Any advice/guidance is appreciated.
  • 1 more comment
  • chill4 Jul 18, 2008
    Thanks, that helps. I assume there is a sensor near, or maybe part of the igniter, that confirms ignition is on before turning on the gas valve. The igniter is glowing (perhaps not strong enough), but the gas valve is not opening. Wife complained of intermittent operation over last week, so seems to have been a progressive failure, not instantaneous. It would be worth swapping out an igniter if there is a reasonable chance that is the cause, but if not, I need to move to the next step. I assume the "safety valve" is integral to the gas valve. Not sure how easy it is to get to.
    Any more thoughts? Thanks.
    Problems with the glow bar system.....You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
  • ruthopp Jan 04, 2009
    The range works fine, the broiler works fine, the oven worked fine yesterday, but today the oven isnt lighting.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
  • chad Alves Jul 18, 2008
    also check the oriface on the valve make sure its not blocked,but it sounds like the cylinoid on the valve is junk,you have to replace the valve,un thread ,pipe wrench on pipe,to brace pipe as you unthread ,when you put new valve on put teflon paste for gas,on thread and screw on,if this helps pleas vote a fix ya
Just repaired my Bosch rangeHGS255UC/02 - would not heat up in bake mode. Replaced the hot surface ignitor. Fairly simple task.
Posted on Jul 23, 2010
I have a bosch oven eight months old. my wife has baking experience of forty years.in this oven cakes and other baked items will not rise satisfactorily. bosch engineer came out and replaced back plate, still no good. any suggestions?
Posted on Mar 18, 2010
Frigidaire oven FGB24L2ASA. Igniter glows red, gas turns on, but does not light.
I appreciate your inquiry, K Ogle!
From what you have described about your Frigidaire range the igniter glows red and the gas turns on but it will not light. It sounds like it could be a faulty burner or igniter and I would recommend having a professional come out to properly assess your range. This does not sound like a simple DIY job. Good luck. -Matt
Feb 17, 2015 | Frigidaire Kitchen Ranges
I have a bosch gas range and found the bake igniter to be faulty. Power to it is switched on and off properly. The broiler also does not work but I havent been able to look at that yet. Are both igniters...
The broiler and oven burner are the same. The igniter can be easily(relative) replaced. Remember the igniter is ON the entire time the flame is present, so it will fail with time.
Jan 28, 2014 | Bosch HGS442UC Gas Kitchen Range
Gs773lxss0 will not light
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Oct 21, 2013 | Whirlpool Ovens
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
Oven will not come on
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on and the igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad. You can also verify that the oven run-away valve is not closed. This valve will be located at the back bottom of the range at the gas regulator. There will be a tab on the regulator housing where the gas pipe goes to the oven. This tab will lift up to close gas flow to the oven. Sometimes these valves can stick causing the oven to stop working. You can try moving this tab back and forth to see if it loosens any debris in the valve. Move the valve while the oven is on and you will be able to hear the burner come on after moving the valve if that was the problem.
May 07, 2010 | Whirlpool GS460 Gas Kitchen Range
Oven will not heat
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Apr 01, 2010 | Tappan TGF363 Gas Kitchen Range
Bake oven does not light. Igniter glows for many minutes but no gas to oven. When I wrapped gas valve with hammer it lights!! When oven burner goes out when reached desired temp, it will not relight...
The igniter needs to draw between 3.6 and 4 amps to open the gas valve even thogh it is glowing the resistance may not be the same . Check the amperage and then replace igniter
Dec 14, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Burner not lighting but igniter is glowing red hot.
The flame sensor is not activating the gas valve. Check or change sensor.
Jul 22, 2009 | Maytag CWG3100A Gas Single Oven
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
My oven wont light
The problem is likely a faulty igniter. It's an easy fix, though an expensive part to replace (about $75 from APP). I had the exact problem and found this answer on another site. Just check out your igniter (under the plate on the bottom of your oven.. remove the screws in the back and lift off that plate).. the igniter is a long flat piece that should be glowing red.. if not.. that's your problem. Good luck.
Jan 11, 2009 | Bosch HGS442UC Gas Kitchen Range
Bosch HGS442UC Gas Kitchen Range Logo
2,699 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
