Just purchased a used rear projection tv but after moving it you see triple lines and we can't figure out how to change this. We tried every one of the menu options
  • 8,617 Answers
Whats the model number of your TV? Please respond to this same post so I will know your symptoms when you post the model number.
Posted on Jul 18, 2008
You can see the red blue and green lines on my tv it is like it is out of sync
I'm not sure what you mean by the "lines". If you mean the image looks like "double" (or triple!) vision, then you need to adjust the red/green/blue convergence. This is especially noticeable with white images on dark background (like text of credits). If this is it, check you manual or explore your menu via the remote. Sometimes convergence can be a problem if the tv was moved or experienced large changes in temperature... or sometimes all by itself!
Jan 22, 2011 | RCA D61W20 61" Rear Projection Television
I have a hitachi ultravision digital hi-def TV model number 53UDX10B from December 2001. The words in its own menu and from my cable box menu are distorted, as well as some words appearing in commercials,...
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Convergence adjustment
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 30, 2010 | RCA P52926 52" Rear Projection Television
The colors are distorted and there is triple images
triple images show failure of convergence out ICs in TV, these are two big black ICs mounted with aluminum heat sink on D board, replace these ICs with same number STK392-560 and problem in your Sony KP-46WT510 will be solved.
Required ICs are available in Part Store.
Let me know any further question, if any.
Thanks.
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
No convergence of color lines
You can get the PT47WX49 Convergence repair kit at the following link which contains all the parts and complete detailed photo instructions on CD so you can do the repair yourself.
www.tvrepairkits.net
Jun 25, 2009 | Panasonic PT-47WX49 47" Rear Projection...
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Severe covergence distortion
for this kind of problem, we consider the lifespan of the RGB GUN lifespan, if the triple image occur on the screen, adjustment should be made and secondly try to measure the 2nd anode by using the high voltage probe
May 06, 2008 | Samsung HC-P4241W 42" Rear Projection...
Triple picture and purple bubble on big screen
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Sep 25, 2007 | Sony KP-48S70 48" Rear Projection...
Zenith 50" R56W36
maybe on your remote press menu and find converence and use the keys to move the red first over the green then move the blue over the yellow ..by standing back and just using the remote....should end up with white lines. and dont hit that button again once set. a tech should do this quickly and charge you minium.
Aug 16, 2007 | Zenith R56W36 56" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
