Question about Sony Handycam DCR-TRV6 Mini DV Digital Camcorder
Battery life? Hi, I recently bought a used Sony Handycam DCR-TRV6 Mini DV. When I tried to charge the batteries it came with (Sony NP-FM50 and the large Sony NP-FM91), neither one showed that it was charging, and after leaving both to charge for hours, still show no charge? I know this is an old camera -- the owner said he bought it in '01 or '02 but didn't use it often, and it apparently sat in the bag unused for 6 years or so. Are these batteries dead? Would a dead battery indicate something in the LCD screen? When I plug in the AC power, it works perfectly... just won't charge either battery! Help!!
  • Sony Master
  • 2,794 Answers
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Posted on Jul 18, 2008
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
Battery is not charged - Sony DCR-TRV 25E
I SUGGEST YOU THAT YOU SHOULD CONTACT SONY,AND ASK THEM TO CHECK UP YOUR CAMCORDER.I THINK THERE IS SOMETHING WRONG WITH THE CHARGE CIRCUIT.
May 24, 2009 | Sony Handycam DCR-TRV25E Mini DV Digital...
Battery NP-FM30
If you want to buy locally , here a list of the biggest Sony authorized resellers near Harrisburg,
In Harrisburg try:
Camera Repair Japan Co-
(770) 849-0555
View
One of the biggest ones is the one below in Lancaster.
Perfect Image Service Center Inc. 1862 Lincoln Hwy East, Lancaster - (717) 397-3019 Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you want to buy online try one of the following sellers:
Sony InfoLithium M Battery NP-FM30, NP-FM50 ... $25.99 –
SONY Camcorder Battery NP-FM30 NP-FM50 NP-FM51$23.00
Feb 28, 2009 | Sony Handycam DCR-TRV250E Digital...
NP-FH100
the 'charging' hole is for you to charge the battery. the 'fh' hole is to power the camcorder. no need to put battery on camcorder in either situation but it is convienent to attach the battery to camcorder.
Dec 12, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony dcr-trv6 shows c:31:30 and beeps
the capstan motor of your camera is stuck up....check the capstan motor is there is some debris insert at the sensor...if nothing you find check also the bushing at the upper part of the motor....
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Trouble using dcr-trv6 mini dv camcorder
This is a common failure in this model and unfortunately will not be resolved without a qualified servicer. The error code indicates a message for lack of reel motion. Most often it is an electronic connection problem and not an actual reel problem. Good luck, magic seadog
Sony dcr-trv6 beeps and shows c'
check the capstan motor if it is stuck up... find if there some debris inserted at the sensor...if nothing you find check also the bushing in the upper part of the motor
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Sony Handycam DCR-TRV6 Mini DV Digital Camcorder Logo
294 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
