Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Crosley refridgerator hi my frezzer stoped frezzing the bottom of the frezzer is hot to the touch?can you help
  • missybabe Jul 22, 2008
    My freezer is hot and the other side is warm, I unplugped it and replug it. I have take all the food out of the freezer. As of this morning my freezer is HOT. I turned up the themostat on yesterday and it is not working? IS this a sign that I need a new one
  • 958 Answers
The only probable cause why a freezer compartment will be hot is if the heater coil that used to heat the ice is still running even there are no more ice in the evaporator.
that will only happen if the bi-metal or thermo disc is shorted.
bi metal is a part where in it would open at 4 degress celcius in order for the defrost heater to stop heating. but if it is shorted then even though the evap temp is more than 4 degrees celcius, it is still heating up ang would make the freezer compart,ment hot.
i hope i answered your problems...
pls rate e..
Posted on Jul 25, 2008
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
I love my refridgerator except for the fact it doesn't make enough ice.I was wondering if there is a setting to adjust the amount of ice it makes..I had a service man to come out and there is nothing wrong...
mrs. justice u should have a setting knob that says freezer colder and by adjusting that knob a little making the frezzer colder so the ice frezzes faster. the faster it frezzes the faster it will dump making more ice. but if that dont work then that box should be equiped to have the more up to date one that has a fan in the ice maker that makes it colder and makes ice faster.. remeber the colder the faster the ice should make. ok try that. later gator.
Feb 22, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My refridgerator dosent work but my freezer does
El problema puede ser el conducto que transfiere el aire desde el frezzer hasta la nevera debe estar cerrado o congelado.
solucion verifica el adjustador de la ventanilla ubicado en la parte superior de la nevera que no se encuentre cerrado si el mismo se encuentra abierto necesitaras a un tecnico por que debe ser problemas con el sistema de descarche que no este funcionado
Jul 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Frezzer is not frezzing
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
Jun 28, 2009 | Refrigerators
My ge profile side by side bottom freezer is hot to the touch
is you condenser fan runnig at all. look in the back ot the unit and if you have a cover plate hten you need to either put your hand close to the opening and feel if there is a draft or if ther is air being blown out that is warm. If not then the condenser fan may be toast.
Jul 16, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Frezzer not frezzing
if you have a old refrigerator it is probaly dying this happened to my parrents fridge a couple years of ago so they got a newer frigde and it works good but if you by a fridge make sure you by name brands
Jun 23, 2008 | Refrigerators
Frost free frezzer
The drain is probably clogged. Use a pipe cleaner to clear and then use a turkey baster and force hot water through. Follow with a weak bleach solution. Drain is usually in the middle of the bottom. maybe towards the back. It is supposed to drain into a pan underneath the unit and then evaporate. Another solution could be a leaky door gasket. This overwhelms the defrost system and causes leaks.
Jun 16, 2008 | Frigidaire Freezer GLRT183TD
is the noise like a hum? touch the compressor if it is really hot, suspect relay/overload combination defective touch the little line that comes out of compressor if cold, suspect the above. if you change the relay/overload combination, and works fine there's your problem. hope to se of some help.
Apr 21, 2008 | Hotpoint RLA30 Compact Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
