Just bought a new wired mic and it cuts in and out right were you plug the cord in to the mic if you wiggle it the mic will cut in and out. mic or cord?
  • 682 Answers
Please apply a lubricant contact cleaner from radio shack near you-in the place where you plug the cord and then put your plug in-out many times(because you said that your mic is new)
Posted on Jul 18, 2008
Bought a prima superchef oven, when I plug it in the electricity trip switch cuts off the power.
or a wire is touching the casing. If it is new, call the retailer. If it is secondhand call an appliance technician.
If it is a UK or Australian cooker, and the wires a fixed into terminals behind a cover on the wall, you have it wired wrong.
Big volts and amps can kill.
http://www.askmediy.com/wiring-diagram-for-a-stove-plug/
wiring diagram for stove plug AskmeDIY
Aug 21, 2016 | Ovens
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
I have an audio technica wireless mic with the 4 pin connector. We have purchased a new lavalier mic but are still having trouble with tge mic maintaining a connection. It keeps cutting in and out if you...
Mic plug has been replaced (new lav mic) so that leaves the mic jack connected to the body transmitter. Corrosion is a possibility...
Radio Shack tuner cleaner http://www.radioshack.com/product/index.jsp?productId=12784986
but I think it's something to do with the mic jack on the transmitter. Some units solder these connectors directly to the internal PC board and after a while, the solder connections break. Have a tech open it up and closely inspect the input jack's solder pads.
Jan 28, 2013 | Audio Players & Recorders
When keying up i hear a ecko coming out of box click sound
This usualy says that there may be a break in the Mic. wiring. To find this out sometimes if the break is at one end or the other you can try while keying up und speaking into mic. wiggle the wires at the plug or where the cord comes out of the bottom of the mic.
Sometkimes the cord can be cut and re-soldered or, replace it regardless. The latter may save you the same problem down the road..........HAVE FUN ! !
Sep 22, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
I just bought one
Typically the wire bends often and severely at the plug (i.e. when using storing, etc.) Every time it bends, there is a chance that the small copper strands in the wire break. The more strands that break, the smaller the wire effectively is. When electricity passes through a wire with a lot of resistance (such as the now-smaller wire right at the plug), it gets hot.
Bottom line: replace the cord before it starts a fire. Failing that, you might be able to cut off the bad section of cord and install a new plug where the cord is still good.
Jul 20, 2009 | Kitchen Appliances - Others
How do you put a new connector on a cb cable?
1) Get an ohm meter.
2) open the mic
3) unclamp the mic cord at the plug and slide the plug case up the cable to enable you to see the wires soldered to the plug.
4) use the ohm meter to check the wire continuity by checking each color wire one at a time. The meter should have full deflection if the wire is OK, make sure to wiggle the wire to make sure it is not intermittent.
Personally I would just change out the cord. If it is going the rest of the wires are going too.
Nov 07, 2008 | Radio Communications
Can't hear sound on one of the headphone's speaker
It's less common for one of the speakers to go bad in a set of headphones. It's possible - but there are more common problems that will cause this. I assume you have tried the headphones on another device to rule our a problem with the device you are currently listening with and using the other device, you still only hear audio from the left speaker.
The wires in the cord that connect the plug to the headphones are very thin and are susceptible to breaking. The most commmon place for these wires to break is at the point where the cord is flexed or stressed the most. Those points are:
1. Right at the plug
2. Where the wire enters into the left and right speaker.
There are occasions where I have seen the wires become unsoldered from the speaker terminals within the headphones themself.
What You Can Do:
1. While listening with the headphones, try flexing the cord back & forth at the plug and where the wire goes into the right speaker. See if the audio will come back and cut out again.
2. What I have done is cut the cord about 3" back from the plug. Go to Radio Shack and purchase a new plug and install a new plug on the cord.
3. You can also take the headphones apart and cut a few inches off the cord where it connects to the right speaker and reconnect the new end of the wire to the right speaker. The goal is to cut away the bad part of the cord and re-attach the good part back.
4. You can try to replace the entire cord but I haven't been able to find replacement (THIN) cords too easily.
Good Luck,
- Jim
Jan 24, 2008 | Radio Communications
Cut Cord
Please specify. What did the cat chew the wire to?
Jun 20, 2017 | Logitech Premium Headset
55 people viewed this question
 Grubhead
Grubhead
