Dell Inspiron Mini 10 Notebook Logo
Posted on Jan 25, 2011
Windows failed to start. a recent hardware or software change might be the cause.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
206
Points
Uninstall Internet explorer 8 and any .net upgrade which is rescent. Try it now and use internet explorer 7 if it is working ok with downgradeor better goto firefox and download firefox.
Other possibility is RAM has failed, if there are two sticks try booting with one stick in theA slot and other removed, alternate the ram sticks to test. If only one ram stick try a similar ram type pc or laptop for ram test, a friend?
Windows fails to start
Is the hard disk, change the hard disk and/or the sata interface wire.
My acer laptop says windows error recovery I plug in my phone to my laptop it says windows failed to start a recent hardware or software change might be the cause
Windows is severely corrupted - critical files are missing. Recover your personal files while you still can and reinstall everything from the beginning.
Getting message that states windows fail to start a recent hardware or software change might be the cause.
you had one drivers crashed that was attached to mother board unattach what ever new changes you pluged in mother board restart system under windows again the device you pluged in isnt compatable to the windows your runing and crashed one of your start drivers.
Windows failed to start. A recent hardware or software change might be the cause.
Press F8 before it boots Windows and select the last known good configuration or go into safe mode and uninstall the last driver you installed in safe mode.
Windows error recovery
you repair ur windows through OS bootable cd, & thn chek it.
Windows failed to start.a recent hardware or software change migh
sounds like a driver issue. Boot to safe mode and do a system restore..you may also get lucky by booting into "last known good configuration" good luck!
Window did not start
insert your Windows Installation Operating System Disc.
Reboot
Boot from cd/dvd.
Choose Windows Repair when prompted.
Follow the directions.....
That should fix it.
You got a hardware/software driver issue or corrupted windows OS files...
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
