Question about Dryers
Dryer wont heat. tumbles ok. cleaned out vents-still wont heat.noticed when turned on it heats for about 5mins then stops heating?
    Champion:
  • 210 Answers
Is this a gas dryer?
Posted on Jul 18, 2008
Same with my wirlpol won't re light
Posted on Nov 27, 2009
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Tumble dryer not heating - White Goods Help
Nov 28, 2015 | Candy Dryers
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
Dryer won't heat up
When is the last time you cleaned out the dryer venting? May be a blockage that is causing the no heat problem. Check directly behind the dryer and also outside at the vent cap. If it's a gas dryer, it will not have a heating coil. The gas burner lights with an igniter. Does the igniter glow orange when dryer is first turned on? If not, it may be broken. Look for broken ceramic piece below where it attaches and replace. Do not touch the ceramic piece on the new igniter, as it is very fragile.
May 15, 2010 | Frigidaire AGQ7000E Gas Dryer
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Dry runs, but does not heat up
dude I just came here to find the same answer with my Maytag dryer! Just 10 seconds ago!
Apr 04, 2009 | Frigidaire GLGR331A Gas Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Dryer has heat and tumbles but won't dry
your vent is stopped or the fan is not turning . most likely the vent under the house
Dec 14, 2008 | Whirlpool LER3622HQ Electric Portable...
Tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Mar 05, 2008 | Dryers
Dryers Logo
220 people viewed this question
Top Dryers Experts
