Question about Cooktops
Replace glass top
I would like to replace one of the glass top panels on a Jenn Air model CVE3400B cooktop, looking for instructions on how to do this. I already have the replacement glass.
Thanks,
Bob
  • kdutil Nov 19, 2008
    same problem but kenmore 790.45499502 stove
  • 59 Answers
Hello Bob
I have attached the link for you to request the manual for that stove....just go there and fill out the form and they will email you the manual in a few hours....I did the same thing and I got it the same day.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US
Eddie Rentas
Tupper Lake NY
Posted on Jul 19, 2008
My glass surface broke on my Jenn Air stove, and I'm having problems finding a replacement part.
if you get me the information i will find you the top but they arent cheep ! you may want to look for used parts ?
Stove model
serial number
any other info you can find on it thanks Frank
Sep 24, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
I need instructions for wiring in replacing a dual burner switch on a CVE3400B cooktop. The replacement switch is different from the original. Do you have a diagram for the new switch that shows how to...
We followed the instructions that came with the switch that addressed a "compound wiring" configuration. We also used the black jumper wire as shown in the instructions.
We got to this solution in a trial by error manner though, because the three of us working the problem were convinced the stovetop was wired in a "piggyback configuration" and tried that road first. It would have been helpful if the instructions had included an explanation of the switch manufacturer's interpretation of "compound" and "piggyback" configuration.
Jan 09, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Need To Replace the Cooktop of my Jenn-Air downdraft
Here is a blowup diagram of the cooktop.
CLICK HERE
Looking up the service manual - it is no longer available.
Hope this is helpful.
Thanks for using FixYa!!
Apr 25, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
I just need to know the cutout dimensions for jenn air smoothtop
i asume that you want to cut your counter to drop the hot plate in turn your plate upside down measure about 1inch smaller than the dimention of the plate is should work fine thanks from gilles
Mar 15, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Feb 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn-air JED8430 cooktop
Fairly difficult but doable for the mechanically inclined. They are all a little different - look underneath to uninstall the entire unit (turn off power first!). It is probably held in by a few screws. The glass is likely held by screws underneath as well. Hope this helps!
Dec 28, 2008 | Jenn-Air JED8430 Electric Cooktop
Glass Top Replacement
There are 3 or 4 screws under the front lip; then the unit hinges upward. Turn off the power first! Once opened you can safaly remove the burners and replace toe top. hope this helps!
Dec 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Aire Cooktop Glass
You can order the replacement glass for about $225 from companies like Repairclinic.com or appliancepartspros.com
Part Number: AP4095442 made by WHIRLPOOL, black
Part Number: AP4096135 made by WHIRLPOOL, white
Dec 22, 2008 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Pitted glass cooktop in Jenn Air Model JGC9430ADS
Did you find anything out? We have had our Jenn-aire gas stove for 1 1/2 years and just noticed today that the surface has bubbled in a spot??? I did clean the oven last week.
Sep 10, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Cooktops Logo
497 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
