Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier Weathermaker 8000Vs
The blower fan will not come on in the cool mode. The fan will not come on when I turn the thermastat to Fan mode. If I turn the thermostat down past the room temperature the compressor fan will start but the blower fan will not come on.
  • pkay70 Aug 17, 2008
    The fan outside blows. No air comes from the ducts. The fan will not blow on fan unless cool is on.
This is nothing short of a circuit board fan relay of a bad motor.. to find out if the motor is good, unplugg the black & white wire , in which white =ground black=hi-speed 120volts and conect them to power -ground and see if the motor works..if does, then its the fan circuit board if not then its a bad motor...
Posted on Aug 25, 2008
My blower on my carrier furnace unit won't turn off? a/c or heater doen't turn on.
gas furnace??? check the start capacitor, put unit in ac mode and see if fan comes on(switch fan to on at thermostat) if it does not a fan problem or capacitor problem. when in cooling mode thermostat controls fan, when in heating mode, furnace controls fan
Feb 18, 2015 | Carrier Heating & Cooling
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
CARRIER WEATHERMAKER 8000.NOT SURE HOW OLD. HAVE POWER,FAN COMES ON,IGNITOR GLOWS,GAS VALVE OPENS,BLOWER RUNS,IGNITOR GOES OUT. CYCLES THREE TIMES LOCKS OUT. ANY IDEAS?
sounds like the roll out switch may be sensing a clog. here is a website that can explain things better, hope it helps Tim:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
Oct 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a new home 1 yr and when the furnace kicks in, I am assuming the fan it makes a noise but as soon as the heat starts the noise is gone, could this be the furnace blower
Check by turning the unit off and turn the fan to on. Do you hear the noise now? The noise your hearing could be coming from your combustion fan assembly instead. Newer furnaces have a in-shot burner and are nosier than the old style of heater.
Jan 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
The fan on my Carrier cental air system is on, and I can't
The fearute that is running your fan so often is designed to provide even, consistent temperatures throughout your home as opposed to hot spots and cold spots. Some customers find this feature to be an annoyance or a waste of electricity. IF you would like to be able to turn off that blower you can have it wired to a switch which would give you either manual off and on or even a timer.
If you want to do this in a barebones fashion you cojuld just find the circuit breaker that controls it and turn it off when you don't want to use any function of air, heat or cool.
Apr 30, 2009 | Heating & Cooling
Hello my name is veronacarrier 8000 weathermaker will not ignite
call the furnace repairman. you have a fairly easy repair but the parts are expensive
Dec 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
464 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
