Question about Kenmore 46462 Front Load Washer
Washing machine has a F03 code when it starts to rinse
Starts to rinse then stops and has a F03 error
  • Anonymous Mar 18, 2014
    washing machine reading F03
  • 57 Answers
Hi I would advise you to check the filters in the water valves and check them for being open circuit
Posted on Jul 18, 2008
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Whirlpool duet front load washer code F03 & E01
I have the same problem and my washer machine is new
Oct 09, 2012 | Whirlpool Washing Machines
HOTPOINT KEEPS FLASING F-03
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
Sep 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Wf540hotpoint washing machine runs the programm for about 10 mins then stops. It then displays error code fo3. can you help
i found the hotpoint web site which enabled me to find the error code F03 which tells me that a thermistor created a possible short circuit.
Jul 30, 2008 | Washing Machines
My washing machine is has the code F03 everytime it starts the rinse cycle
Hi I would advise you two check the water valves for open circuit
Jul 18, 2008 | Frigidaire Washing Machines
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Kenmore 46462 Front Load Washer Logo
659 people viewed this question
Sal De
fordexpert
Robert Rankin
