Question about Home Security
Sears craftsman gt3000 kohler 23 horse power 48 inch deck
I start my lawn tractor and it runs fine... when I put it into gear, it will run fine for 30 to 40 seconds and then it starts to want to dye out. Then all of a sudden it will fire back up and run again. It repeats the wanting to die out every 30 to 40 seconds and will refire up again. it just will not run smoothly.
I replaced the gas. I put in a new fuel filter. I also cleaned the carb. I had a new carb put in by Sears in 2005.
Could you please help me diagnose this problem?
I would really appreciate it!
  • peskey1876 Aug 26, 2008
    I tried both of your suggestions...
    It runs for a little longer, but it still wants to die out. Is there a chance you give me a little more advise? I cannot see why this tractor is giving me such a hard time. Ugh!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
If it even has a float. A lot small engines just have a diaphragm type pump.
I was thinking governer sticking or loaded with grease. Right at the top of the engine is a flywheel with fins on it., Those fins serve to put an amount of forced air on the governor so it does not overrevv. This gov connects directly to the carb but it could be any number of fuel issues.
When in doubt spray the gov/ flywheel/engine with a foaming engine cleaner while warm then later spray it away.
After that if it still continues I would rebuild the carb, They usually come extra so buy a new float, too. while you're in there it is worth the effort. Most of all make sure it's adjusted right or it will do what you describe. New kits use a cardboard feeler gauge to set it. But you could have any number of sticking/varnished needle valves in there. Crab rebuilds are not expensive but it's good to set it out on a cleanly newspapered cardtable with a magnet and a can of carb cleaner. These are tiny parts... tweezers help... small hands of a kid would, too. But it will save yourself 1 to three hundred dollars.. I've rebuilt many from little two cycles to car ones.
Posted on Jul 14, 2010
    Sniper:
  • 67 Answers
It sounds like the float on your carb needs cleaning,im not sure how you cleaned your carb,but if you take out the bottom bowl ,it unscrews and youll see the float right there,check to see that it lifts up and down with no resistance,if ok I would check the safety switch on your seat,the one that shuts your tractor off if you get up off the tractor while its running,its probally on the way out,if this is helpfull please vote me a fix ya
Posted on Jul 18, 2008
Can the overhead valves on a 16hp sears craftsman with a kohler engine be the reason why it won't start and if so, can I adjust them
Valve clearances will also effect the decompression valve in the engine, if they are too wide the valve lifter will not work and the battary will not have enough energy to crack the engine.
Jun 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Troy Bilt Horse Lawn Tractor Transmission problems
you need to screw the transmision adjustment in so that it is push all the way in to gear.
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Blowing fuse
youve got a short in the wireing ,prob right at the clutch peddle switch
Mar 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replace key assembly
any small engine repair shop should carry that switch - or sears . com - just put in your model number
Oct 21, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to adjust the idle on my lawn tractor
there should be one screw at the top of the carb, that is the fuel intake adjust screw. turn clockwise all the way down without force. start the mower and slowly turn clockwise until rpm sound right
Oct 21, 2008 | Craftsman Garden
Home Security Logo
1,210 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
