Question about Baby Lock Espire
ESPIRE SEWING MACHINE - MODEL ESp baby lock
MY FEED DOGS ARE NOT FEEDING. I PAID AN ARM AND A LEG TO GET IT FIXED ONCE BUT IT STILL ISN'T WORKING PROPERLY. ARE THE PLASTIC GEARS WORN OUT?
  • sheerness Jul 20, 2008
    I HAD CLEANED THE MACHINE WHICH SEEMED TO FIX THE PROBLEM FOR HALF A DAY AND THEN IT RETURNED. I MAY TAKE IT BACK TO THE PERSON WHO "FIXED IT" WHEN I HAVE TIME. THANKS FOR TRYING.
  • Anonymous Dec 05, 2008
    The feed dogs are not feeding the material through. I cleaned it and it did not help.
  • 323 Answers
Take it back to where you had it repaired and ask the dealer to make it work under his warranty. Maybe he can tell you exactly what's wrong with your machine. Usually it is a pressure problem or the feed dogs are filled with lint or they don't rise high enough above the needle plate to work. Take off the needle plate and check them.
sewman7
Posted on Jul 18, 2008
Creative pro baby lock sewing machine feed dogs will not work
There is a switch that lowers the feed dogs when using the embroidery arm. look on the back of the freearm, might be on the end of the sewing free arm. There is a switch or control for this issue.
Cheers,
Embroidery Services
San Diego, CA
Sep 16, 2017 | Baby Lock Sewing Machines
Esante baby lock ESe2 dog feed won't feed material.
check to see if the feed dogs lever is in the up position for sewing, if not move the lever to the up position, if the feed dog lever moves and it doesn't make the machine sew, then the feed dogs need to be checked.
Nov 19, 2013 | Sewing Machines
Machine will not feed fabric except for the first couple of stitches
if you have a manual check to see where the feed dog lever is and
see if it's in the up position for sewing or the down position ,
also possible that something is wrong with the feed dogs and
they made need some type of adjustment.
Feb 12, 2013 | Baby Lock Espire
My Babyloc serging machine does not feed the material through! The teeth appear not to move the fabric. I have taken off the plate to see if any fabric is underneath, but there is no dust or fluff. The...
I had this same problem with a Babyloc machine. The two hex set screws that hold the feed dog assembly to the drive shaft may have worked loose. You can confirm this by turning the machine by hand and observing the movement of the feed dogs. Tighten the hex screws using the correct size Allen key. You will most certainly need to adjust machine's timing. When working properly the feed dogs should rotate front to back in an elliptical pattern, remaining down during the down cycle of the needles. If the set screws have worked loose you may also have a problem with the stitch length adjustment cam (located on the left side of the machine.) This problem will manifest in a machine that is locked up or slows down during use. When dry the cam will heat up, expand and seize within its bearing sleeve. To fix this problem you will need to remove the small plastic cap (with red arrow) covering the screw securing the cam. It is usually also necessary to remove the connecting rod/sleeve that the cam rides in. Once both of these parts have been removed, you will need to carefully separate them and resurface the inside of the sleeve. This can be done with a very fine (500grit or higher) emery paper. Once the cam fits inside the sleeve without binding, reassemble using sewing machine oil or lithium grease and adjust feed dog timing.
May 17, 2011 | Baby Lock Sewing Machines
Material is stuck in the machine under the feed dogs and I can't get it out
Remove the needle, presser foot, needle plate, & bobbin.
Snip at the fabric and remove in pieces with tweezers - do this gently.
Feb 03, 2010 | Baby Lock Espire
Feed dogs will not go up
remove the embroidery arm and before yo place the sewing box attachement move the feed dog switch to the left/up position. (its located on the frontside of the machine, which is visible when you remove the embroidery arm.
Jan 06, 2009 | Baby Lock Esante
Feed Dog problem
Here are some common reasons that the fabric won't feed:
1. Stitch length is set to zero, or machine is in button hole setting
2. Feed dogs are dropped (free motion setting)
3. Broken gears (typically in old singers)
4. Presser bar not coming down - may be bound up.
5. Lots of lint under the needle plate (in between the feed dogs) preventing feed dogs from raising.
Hope this helps.
Nov 29, 2008 | Baby Lock Esante
Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
585 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
