Question about Kenmore Refrigerators
Freezer and fridge not real cold no ice
All fans are working compressors runing just not cold enough icmaker stoped working too
  • giovanni007 Jul 18, 2008
    the fans and compressor is running in the freezer i pull of the panel
    no ice however when i turn it on some frost shows in the begining of
    the coil i cleaned every thing as best as i could still its not very
    cold its about 65 degrees
  • Mike Durland
    Mike Durland May 11, 2010
    any frost buildup in the back wall of the freezer?
    Sniper:
  • 67 Answers
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
if this helps vote me a fix ya
Posted on Jul 18, 2008
  • 481 Answers
  • it sounds like the compressor is weak.
  •  (you should see the coils develop frost from one side to the other within a few minutes. this is why refrigerators have to defrost twice a day.)
  • it is not building up enough pressure to move the heat effectively.
  • if this is the case then it is a complicated and expensive repair.
Posted on Jul 20, 2008
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: freezer and fridge not real cold no ice
Inside the fresh food compartment there is a defrost timer behind the control panel. There will be a small hole that you can place a screwdriver through and turn clockwise s;lowly until you hear the refrigerator stop. It should remain stopped for about 30 minutes. If not you will need to again turn it again slowly until it starts. If this happen the timer will need replaced. The part number for the timer is WRX9X489 This is correct providing the model you have is the model listed above your post.
Go to the link below and enter your model number in search feature. this takes you to many just like yours, they are same just little differences. Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 28, 2009
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
My freezer is not getting ice
If the freezer is not cold enough you may have a compressor problem. First totally defrost the fridge. then plug the fridge back in and check that the fan in the bottom that cools the compressor is working. the cold control can fail so turn the cold control to the highest setting and note if the compressor stops running before the freezer starts making ice. If the fridge just runs and runs and does not get cold enough to make ice you have a somewhat serious problem. the compressor can be replaced but it is expensive and you might be better off to get a different unit (new or used) that will work correctly. Most used appliance stores will have something that will work well and won't cost that much.
Apr 18, 2011 | LG Refrigerators
My compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
Fridge not getting cold tempture on high number 7 what should we do to get it runing
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 25, 2009 | Haier BC112G Wine Cooler
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
May 28, 2009 | GE 21.7 cu. ft. Side-by-Side Refrigerator...
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
Freezer fine /After power went out twice fridge not cold enough
In back of the refrigerator is a removable panel behind which is the compressor. Listen for a hum and a click. If you hear those sounds the compressor may have failed. Behind that same panel is a condenser where heat is removed from the refrigerating system. Make sure it is clean and check that the fan operates when the compressor runs.
Jun 07, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Refrigerators Logo
252 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
