Canon pixma iP6000D error code 6A00, won't go away even after turning on and off again.
  • sander Haan Dec 01, 2008
    I've the same error code.
  • Anonymous Dec 18, 2008
    Me too. What a waste of money canon pixmas are.
5 Suggested Answers
  • 18 Answers
SOURCE: canon pixma ip 3000 6A00 error
the error on this printer relates sheet feeder and or the logic board or the purge unit tin the printer if one of these items fails in the printer it causes this error the printer needs to be takewn to a canon service agent in your area for repairs the error can notbe fixed by the user. It class a a service error on the printer
Posted on Dec 04, 2007
ctf1800
  • 4402 Answers
SOURCE: Canon Pixma iP6000D Inkjet Photo Printer
this is all i could find out
ssue: ERROR LCD: Error code (5xxx through 9xxx)
Solution: Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Posted on Jan 15, 2008
  • 6 Answers
SOURCE: will not turn on error 6A00
This is what I found from a service manual: AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ***'y (QM2-1786)*1
What does it mean? This link should be useful: http://www.fixyourownprinter.com/forums/inkjet/37440
Posted on May 30, 2009
komguy
  • 2306 Answers
SOURCE: canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Posted on Jul 24, 2009
bschilz
  • 2049 Answers
SOURCE: Canon pixma all in one mp500 error code 6A00
6A00 is a problem with the sheet feed unit.
Manually move the print head left and right, and turn the printer on/off. I would also inspect the rollers for ANY debris... it can often be fixed by using "canned air" and blowing the interior out completely.
Posted on Apr 29, 2010
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
I get error code 6A00
The link below could be helpful for you to solve your printer problem.
Fix your own printer Forum
Regards,
Ron
Feb 24, 2011 | Canon Pixma iP6000D InkJet Photo Printer
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Apr 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP800 error code 6A00 - what does it mean
Canon says you need to send it to them to fix.
Before you do, turn the printer off and try moving the carriage back and forth a few times. At the same time, look for any debris in the area that could be jamming the sheet feed unit.
Turn the printer back on and see if the error goes away. Several other people with this problem report solving it this way.
Oct 05, 2009 | Office Equipment & Supplies
Canon pixma mp800 error code 6A00
Jul 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Will not turn on error 6A00
May 30, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Sir iam using cannon pixma 1p6000d photo printer , when i try to switch on my printer i am getting error message error code is 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2009 | Canon Pixma iP6000D InkJet Photo Printer
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Feb 19, 2007 | Canon Pixma iP6000D InkJet Photo Printer
100 people viewed this question
k24674
