Question about Jazz DV-179 Digital Camera
Battery say it is charge
But it wound not turne on
  • 90 Answers
Please send inquiry to Christah@Jazzcameras.com. She will need to know model# and when it was purchased along with a detailed description of the problem.
Posted on Aug 29, 2008
Tip
How to maintain camera battery and lengtens camera battery life ?
Camera batteries tips for use and promote battery life:
Camera batteries could cause failure of turning on a Camera easily. Try to turn battery off and turn on Camera through the outside electrical source when Camera can't turn on and all the indicator light if off.
Why Camera battery can't charge to 100%?
Generally speaking,batteries for Camera usually can't charge to 100% due to the display problem but not the battery fault. After adjust the electricity display 1-2 times,it will show correctly.
Whether Camera Samsung BP70A battery life will be cut down when Samsung BP70A battery hasn't run out and is charged?
Samsung BP70A Battery life is generally computed by the times of full charge.Lithium battery usual have 300-400 times and once is defined charge it up to 80%-90%. So don't be worried.
What is the best temperature for battery storage?
Because very hot or cold conditions could affect a battery's performance and such as canon lp-e8 battery life,you'd better store the canon lp-e8 battery in a place with recommended storage temperature of 15°C (59°F).
Camera Batteries Note Of Don't:
Battery can be only used on the designated equipment.
1.Do not heat the battery or dropped into the fire.
2.Do not put it near fire or into the car at temperature over 60'.Do not discharge under these circumstance.
3.Do not put the battery into the water, do not make them wet.
4.Do not put the battery with necklaces, hairpins, coins, or screws and other metal items together in pocket or bag, they should not be stored together with the battery with the above-mentioned items.
5.Do not reverse the positive and negative when load the battery.
6.Do not use sharp objects to pierce the battery.
7.Do not break down the battery.
8.Do not weld the battery directly.
9.Do not use battery with serious wounds or deformation.
Before use your new battery, please read the operating instructions. Improper operation may lead to battery heat increasing, fire, explosion, destruction or attenuation of battery capacity.
on Jun 01, 2010 | Cameras
I have a 2002 Lexis RX 300, every time I turn the key on to start the car the alarm start beeping. Is there a way to stop this. It beeps even turning the car off.
So I talked to someone who suggested my battery might be dead and that I try charging it, but as "Bullmtnbiker" mentions, the horn blasted as soon as I connected the negative terminal of the battery to charge. Finally, I just tried connecting it and running into the vehicle to start it, and that stopped the horn blasts immediately and it started and ran fine. I just hooked up to a trickle charge overnight to get the wounded battery back in shape.
Sep 29, 2016 | 2002 Lexus RX 300
How do i get my battery to fully charge on my tablet its less than a year old
As a battery ages it may be unable to charge completely. It may be time to replace it.
Sep 11, 2014 | Proscan Recertified - PLT7035 4GB NAND...
What can cause my Homelite cordless lawn mower UT13126 to stop after 3 minutes when the battery is fully charged
Your rechargable battery may no longer accept a full charge if it is old.. Get it tested at a garage.
Possibly the battery is OK, but the lawnmower blades are too stiff to turn and the battery soon gives up. Check blades can rotate freely, and have not got entwined grass or string etc wound around the shaft
May 15, 2014 | Electric Lawn Mower
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
Stem is broken watch cannot be wound
An Eco-Drive does not need to be wound. It has a rechargeable battery in it that is recharged by light hitting the dial of the watch.
All Eco-Drives have to be allowed to get light on them to recharge the battery. If they are put in a drawer or covered all the time by shirt sleeves then the battery will drain and they will not work.
If the battery is completely drained then the battery will not be any good and will need replacing by a qualified watchmaker.
Try setting your watch under a light or in a sunny spot with the light shining on the dial. If in the sun light it should take a few hours to charge the battery. If under a light it can take more than 18 hours to fully charge the battery.
But if the charging does not hold then the battery is no longer good and requires replacement by a qualified watchmaker.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 09, 2010 | Citizen Eco Drive Largo AT0424 59E Gents...
Juts got the watch, wound it, worked then stoped, wound dead
These watches are self winding (mechanical spring), so need to be worn (or gently oscillated) to wind them up.
The catalogue for this watch says it should run for 72 hours when fully wound.
Depending on when the watch was made, it could be that it needs a clean.
Try wearing it for a few days to see if it keeps going.
Feb 02, 2010 | Rolex Daytona 116520 Wrist Watch
1995 Camry will not crank....replaced fuel pump, fuel filter, plug that goes into fuel pump...will still not crank!!! Battery was dead, as it sat forever...jumped it off and it ran fine...went to drive it...
If it keeps on cranking over and over then the battery should be fine but to check. Take a volt meter and put it across the battery and make sure it's around 12v
also check to see that the injectors are putting gas in the combustion chamber as well with the spark plugs delivering the spark.
Check to see how worn out your distrubuter is (cap and rotor)
hope this helps!
Aug 12, 2009 | 1995 Toyota Camry
I have a 1950 Pontiac Chieftan with a straight-8 engine. When I push the starter button I hear a click and a hum, but the starter won't turn over. Lights and horn work fine, so I think electrical system is...
if the battery is to weak it cannot turn the motor using the charger power .with a full charge battery and those problems bad starter or froze up motor. if you must have charger on it to have power bad battery
Aug 06, 2009 | 2004 Nissan Maxima
Jazz DV-179 Digital Camera Logo
15 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Prashant Hattangadi
Level 1 Expert
Are you a Jazz Camera Expert? Answer questions, earn points and help others
