Question about Yamaha Audio Players & Recorders
How to hook up directv rev to yamaha rev
I need know how
rg
2 Suggested Answers
  • 165 Answers
SOURCE: need to connect tv, satelite and dvd to yamaha rxv1700 receiver
hello i think the question is how to connect two equipment (dvd and directv) your tv has video 1 video2 aux, put one at any input and the sounds out from tv go to receiver inputs,this way you listen what is on tv in your amplifier....................saludos
Posted on Nov 24, 2008
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
I have a yamaha receiver with HDMI outputs for direct tv, and a DVD player. How do I hook up the direct tv, HD DVD, and yamaha receiver? Where do the inputs go?
Does the Yamaha have HDMI inputs? Usually you would connect the directv and dvd player via individual HDMI cables to the Yamaha (input)and then the Yamaha (output) to your TV also via HDMI.
Dec 21, 2009 | Yamaha HTR-5640 Receiver
Projector menu keeps popping up after Directv box change
Is the projector menu that comes on the menu that tells you the projector is not receiving an input signal?
Dec 18, 2009 | Refrigerators
Cannot hear anything but speakers are fine. hooked up to directv box, LED tv and blue ray player.
It may be that your hdmi wires are damaged or plugs are loose. Try to tune it.
May 06, 2009 | Audio Players & Recorders
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
I CANNOT GET MY OLDER VCR TO WORK WITH NEWER EQUIPMENT.
The VCR is straight analog/composite and if you are trying to get it to show up on the TV via the HDMI connection between the receiver and the TV it is probably not going to work correctly until you add a dedicated pair of audio connection from the receiver to the TV...
Mar 16, 2009 | Jensen JW250 Main / Stereo Speaker
Sound like "gırgırgır"
Your cam chain tensioner needs to be replaced mine has been done twice.
Feb 18, 2009 | 2005 Yamaha FJR 1300
Need to connect tv, satelite and dvd to yamaha rxv1700 receiver
Nov 24, 2008 | Yamaha RX-V659 Receiver
No sat-go reception
I believe there is a special package that you must have to use this item. Contact directv sales.
Sep 13, 2008 | Directv Sat-Go Portable Satellite TV...
Pioneer spec 1 and spec 2 hook up with RG 2 processor and audiosource eq 1
preamp out---------to equalizer in-------------equalizer out----to amplifier in-----------amplifier out----------to loudspeakers.
Jun 12, 2008 | Pioneer Audio Players & Recorders
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
