posted by nguyenef on Jul 18, 2008
I have a 61" samsung DLP tv one of the earlier models. I just bought the brand new lamp. I have a problem when I turn on the tv, it sounds like the tv is trying to come on but i get no picture and the power switch keeps on turning on and off. Finally all three light are blinking. How do I know that I had a bad lamp, a bad ballast, or a bad color wheel. How do I test the balast? Can I test the voltage output where the lamp is plug in? My email address is nguyenef2004@yahoo.com.
thanks.
Comment by nguyenef, posted on Aug 12, 2008
Thank you for your information. I've the lamp out (the secure switch down for door closed), the ballast did not "strike" or give an arc sound. The color wheel does not spin. The TV did not have any bad sound at all, can the color wheel just die without warning? What do I need to do? Replace the color wheel? Thanks,
Best Solution
posted on Jul 29, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
with lamp out (door closed) the ballast should "strike" or give an arc sound, trying to fire the lamp. If it does not do that maybe the color wheel is not spinning up - has to do that first.........then the set will try to fire the lamp
Rating Locked! (?) nguyenef has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Samsung DLP HL-P5663W 56" TV
Email this problem
Email this problem
Can you Help with these Standard Televisions problems?
Samsung DLP Color Wheel...
I broke the CN socket that the... Answer This...
DLP 61 inch Samsung Television
I purchased my TV 4 years ago... Answer This...
Repair Service
Find Standard TV Repairman Near You:
