Question about HP Pavilion MX70 17" CRT Monitor
Moniter wont work
I just updated my computer with windows xp but right before my computer makes it to the user log screen it shuts off and wont come on
    Problem Solver:
  • 12 Answers
Possible reasons for this is a defective video card or the monitor itself or Windows installation failure. First, isolate the problem by swapping a working monitor to your system and check if the problem still persists. If it still doesn't work, then video card is the culprit. Some defective video cards function only on the lower resolution settings, which is the default resolution in the installation process of Windows XP. When the installation is finished, boot loader set the user interface to a much higher resolution which the defective video card is incapable of.
To further verify this, try pressing F8 and start Windows XP in a Safe Mode. If it boots properly, then Windows XP is incapable of going across the normal mode.
Posted on Aug 01, 2008
Administrator password to login not working
Microsoft's latest operating system, Windows 7, and its predecessor, Vista, offer a new layer of security that is different from previous releases, such as XP or 2000.
The earlier Windows versions treated all users as system administrators by default. With Windows Vista and 7, all accounts are treated as limited users.
The User Account Control utility provides elevated permissions when required and prompts users for those permissions.
You can control UAC behavior in Windows 7 so it does not prompt you for these permissions.
Start your computer with Windows 7 and log in as you normally would. Your desktop should appear, and any background applications should be closed.
Click the Windows "Start" orb at the lower left corner of your screen.
Click your account picture at the top right of the menu.
You will be presented with a window that allows you to make changes to your user account.
Click the link that says "Change User Account Control Settings."
Look for the User Account Control options slider.
The default option of User Account Control is to notify you only when programs try to make changes to your computer or you install new programs.
The option directly below that does the same thing but does not dim your desktop.
The "Never Notify" option at the bottom of the list eliminates the prompts for permissions.
Move the slider to the bottom of the options window.
Click "OK."
You may be prompted one last time from User Account Control to confirm your settings and reboot your computer.
or
Log in as an Administrator on Windows 7
If you've recently upgraded from Windows XP to Windows 7, you're probably wondering how to log in as an administrator. In Windows XP, the administrator account was clearly visible from the log-on page, but it's no longer there in Windows 7.
Although there is an administrator account, it must first be enabled with the Windows command prompt before you're able to use it. Enabling the administrator account lets you troubleshoot problems with programs on your computer.
Click on the "Start" button, and then type "command" into the search bar.
Right-click "Command Prompt" when the results appear.
Click "Run as Administrator."
The command prompt opens.
Type "net user administrator /active:yes," excluding the quotation marks.
Hit "Enter."
Click "Start," and then click "Switch User." Click the "Administrator" icon to log in.
Aug 04, 2013 | Computers & Internet
How can i log in my Delloptiplex 760 computer,when its auto logging off
If running XP
A log-on loop on your Windows XP computer is a difficult situation where the computer never completes its boot cycle, restarting intermittently ad nauseam.
This issue indicates a major problem with the boot functionality of your XP system.
Restore the computer to working order by utilizing the repair and restoration utility on your XP system disk.
Insert the XP disk into the computer.
Restart the computer.
Press any key when prompted to boot from the disk.
Press "Enter" at the first screen and "F8" at the license terms.
Highlight the drive containing XP and press "R," repairing the operating system boot files and removing the log-on loop.
or
Windows XP sometimes has a glitch when you are logging in to your user account in order to boot the operating system.
The glitch logs you in and then logs you off the account.
This problem is usually caused by one of the programs that load during the computer's start-up.
Fixing this issue is a matter of ensuring that whatever program is causing the problem doesn't start up as soon as you start your computer.
or
Power on the computer and allow it to get to the user logon page normally.
There is no need to start up the computer in "safe mode."
Click the user who is having the issue and type in the user's password if one is set up.
Press and hold the "shift" button on your computer keyboard as soon as you see the tool bar load up at the bottom of the screen but before any other program has a chance to do so.
This stops any "Startup" program from running and logging you off.
Right-click the "Start" button on the bottom left of your screen.
Select "Explore" from the menu that appears.
Double-click "Programs" from the list on the left side of the window that pops up.
Double-click "Startup."
Select all the files inside the "Startup" folder by dragging a box over them.
Right-click anywhere on the selected files.
Select "Delete" to delete those files.
Note that deleting the programs from the "Startup" folder does not delete them from your computer.
All this does is make it so that these programs no longer start as your computer is starting so that any error in the running of the programs doesn't interfere with logging in to your account.
Hope this helps
Nov 13, 2012 | Dell OptiPlex 760 PC Desktop
Icant log in my computer.when log in,with in few seconds it logging off automatically
If running XP
or
or
Hope this helps
Nov 13, 2012 | Dell OptiPlex 760 MT Desktop Computer
When istart the computer cant log in ,eventhough my user name and password is correct
or
or
Hope this helps
Nov 13, 2012 | Dell OptiPlex 780 MT Desktop Computer...
Hi, When I try to run Windows Update, it tells me that updates KB973688 and KB954430 failed to install. They can't be deleted and then reinstalled because they never actually installed in the first...
acutually you dont need to wory much about the failed updates. it wiil come again next time when your system automatically updates. ther is no harm if you update failed.most of them are security updates. a good antivirus will work fine.dont wory,
good luck
Sep 19, 2011 | HP Mini 1000 Netbook
My computer security updates fails all the time with numerous codes: Security Update for Windows XP (KB2555917) Security Update for Windows XP (KB953155) Security Update for Windows XP...
Check this answer at answers.microsoft... it may be as simple as turning off your antivirus while installing these update. You may also try the installation in Safe-mode.
Aug 09, 2011 | Computers & Internet
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
Start Menu Picture Disappeared Suddenly
Turn the Welcome screen on or off It sounds as if you accidentally turned off the welcome screen. Here's how to turn that function on and off:
To turn the Welcome screen on or off
You must have a computer administrator account on a computer that is a member of a workgroup or is a stand-alone computer to turn on or turn off the Use the Welcome screen feature. Logging on at the Welcome screen is not available on computers that are members of a network domain.
  1. Open shortcutcold.gifUser Accounts in Control Panel.
  2. Click Change the way users log on or off.
  3. Do one of the following:
    • To specify that users log on to the computer using the Welcome screen, select the Use the Welcome screen check box. A user logs on to the computer by clicking his or her user account name on the Welcome screen. If a password is assigned to the account, the user is prompted to type it.
    • To specify that users log on to the computer without using the Welcome screen, clear the Use the Welcome screen check box. The Welcome screen will no longer appear when you start the computer. To log on to the computer, type your user name (and password, if you have one) in the standard Log On to Windows dialog box.
note.gif Notes
  • To open User Accounts, click Start, click Control Panel, and then click User Accounts.
  • Fast User Switching is available only when the Welcome screen is turned on. For more information, click Related Topics.
I hope this helps. Please let me know if you require further assistance.
Feb 26, 2009 | Microsoft Windows XP Professional SP2
My laptop won't shut down properly!
Is it possible that you have changed the settings of what buttons do what on your system? E.g. you could have changed the power button to "switch user" instead of "shut down", to check this (in XP) go to "Power Options" (in Control Panel" and then click on the "Advanced tab" at the top, then select "Shut down" from the drop down menu at the bottom of the window.
If this is already set to shut down then maybe you could do a system restore in case another setting has been changed, restore it to before the PC started doing this.
Alternatively try actually choosing "Turn off Computer" from the Log On screen (press Ctrl + L to get to this screen, or choose switch user/log off). If you are using Vista I beleive that there is a shut-down option from the Log In Page there (which again you can access by pressing Ctrl + L on the keyboard.
Hope this helps!
Dec 29, 2008 | Computers & Internet
Desktop properties (desktop and screensaver tab is missing)
The following is solved me
Well if anyone is interested and for general knowledge these are the 3entries that were killing the Desktop and Screen Saver tabs in XP. Hupigon13 seems to be at the root of it all.
Quote: Microsoft.Windows.System: Settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispBackgroundPage!=W=0
Microsoft.Windows.System: User settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispScrSavPage!=W=0
Hupigon13: Settings (Registry value, fixed)
HKEY_LOCAL_MACHINESYSTEMControlSet001ServicessrImagePath=...SystemRoot...
Read full story here
http://forum.osnn.net/showthread.php?s=f44e1bb094fbae9305c9f0c9999c52e7&p=841430#post841430
Jul 16, 2008 | A4tech PK5
HP Pavilion MX70 17" CRT Monitor Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
