Question about Microsoft Xbox 360 Console
Two red rings
After playing for less than 10 min the red rings come on and the game stops
    Scholar:
  • 29 Answers
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Posted on Mar 14, 2009
  • 116 Answers
That means your xbox is broken
Posted on Jul 18, 2008
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: after playing a game for 10 min. or less playing
Hi. This two light error code is signaling that the console is overheating.
Alternatively
Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
1. Let the Xbox 360 console cool.
Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
2. Verify that the console has sufficient ventilation and that the fan is operating.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
* Do not block any ventilation openings on the Xbox 360 console.
* Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
* Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
* Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
DO NOT EVER PUT YOUR CONSOLE IN THE FREEZER OR OUT IN COLD WEATHER
Some people think that doing this might help "fix" an overheating console, in fact doing so could cause even bigger problems. Electronic devices like your console are made to function at and around room temperature, extreme cold temperatures can often cause just as many problems as extreme warm temperatures (such as overheating). Also if the console is located in a dramatically cold area while running, the difference in temperature between the hot console and cold air can create condensation which in turn will short out your console making the situation far worse. Condensation will happen more quickly if your console is overheating due to the greater difference in temperature. In short... DON'T DO IT.
A more aggressive Solution to overheating is to improve the cooling system of the console. The best solution is to replace the thermal compound. If you attempt this you do so at your own risk. If you're console is still under warranty it is recommended that you contact MS for a replacement before attempting to fix it yourself.
Posted on Nov 02, 2009
Game play freezes after a min playing games and videos
this usually happens when u have the red ring of death, to make sure of that check your xbox when ur game freezes, if red rings come up u have the red ring of death. u can contact microsoft and they will wither fix ur console or send u a new one
Feb 26, 2010 | Sony Playstation 3 (PS3) Console
After playing a game for 5 min. or less playing on an xbox 360, the screen turns off and the xbox has 2 red lights on the ring of light the console is still on and the controller is still doing what it was...
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
Jan 20, 2010 | Microsoft Xbox 360 Console
2 red lights
Your xbox is overheating.
1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. 3. If the two lights continue to flash after trying the above steps, you'll need to contact Xbox Customer Support.
Jul 13, 2009 | Microsoft Xbox 360 Console
your xbox 360 is overheating its called the red ring of death look it up on google you can have microsoft fix it if you still have a warranty on it, it shuts down so none of the components in the xbox 360 get damaged
May 30, 2009 | Microsoft Xbox 360 Console
Flashing red lights
Your xbox might be overheating. Read http://support.xbox.com/support/en/us/xbox360/kb.aspx?ID=907533&lcid=1033&category=hardware for more information.
Apr 10, 2009 | Microsoft Xbox 360 Console
During game play,game shuts off and two red rings appear/
its very possible your xbox is having overheating problems. I had the same issue with mine, and i had to send it back to microsoft 2 different times, but after that it worked fine. I would try sending it back to microsoft, and see what happens from there.
Mar 30, 2009 | Microsoft Xbox 360 Console
Dont do those fake youtube videos this is how I fixed mine after trying endless Internet hoaxes http://xbox360repaircenter.info guarantees you be playing in 2 hours for cheap
Nov 29, 2008 | Microsoft Xbox 360 Elite Console
asdasdhgaiouhsdpgiohasd;ilgkhas;doilgk
Oct 28, 2008 | Microsoft Xbox 360 Elite Console
My xbox 360 has the 3 red rings and wont work. my brothers played it for about 10 mins then i ate lunch then it turns out it wont work.
this is called red ring of death. Call microsoft it is free to you and they will service it and send it back you within a week or so.
Jul 02, 2008 | Video Game Consoles & Games
Game freeze and red lights
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Nov 28, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
85 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
