Question about Frigidaire Refrigerators
Water collects in the bottom of freezer becomes ice heater turns on(seeing heater style units glow red)melting the ice causing it to drip on to floor.FRIGIDAIRE model FRS26ZGEW1
    President:
  • 1,462 Answers
Drain is blocked probably with ice. take rear panel off, melt ice off with hairdryer and follow up with hot water till water flows away freely
Posted on Jul 18, 2008
Why does ice collect at bottom of freezer?
The freezer has the only coil in the unit that gets cold. IT does build up with ice. The unit has a defrost heater that comes on to melt the ice. The water from this process is supposed to drain down a tube into the bottom pan that you cannot se under the unit. IF the tube is plugged with ice or other debris, the water from the defrost cycle cannot drain correctly and runs into the bottom of the freezer. There is quit a bit of work involved in getting this to work again.
Jul 18, 2014 | Whirlpool Refrigerators
Tip
Refrigerator not cooling-freezer section icing up
Refrigerator not cooling, ice forming on back of side-by-side freezer:
Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to expose iced-over coils. Use a fan to speed up defrosting. Put a towel or a plastic drip pan in the bottom of the freezer to collect melting water (rather than letting the water collect and maybe overflowing in the drip pan underneath the refrigerator).
After defrosting, by temporarily replacing the freezer back panel and turning on the unit, the refrigerator may operate OK for about 3 weeks before the next excessive ice build up.
Possible problem- a burned out Defrost Heater.
To check: After defrosting, turn off power to or unplug the refrigerator.
Unscrew the Defrost Heater bracket (2 screws). When loose, unplug the two wires connected to the unit. Have the unit checked, or use an ohm-meter to check continuity. If unit measures "open", high resistance, replace the Defrost Heater and bracket. If the heating element shows continuity (or low resistance) the heater is probably OK and you have another problem. Now you may need to contact a repair man.
on Jul 06, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Excess water dripping into refrigerator from freezer. I am in the process of defrosting. Ice build up behind freezer back wall. Do I need a new heater or will clearing the ice from drains suffice?
Clearing the ice build up is a good start,the problem though is the drain pan under the coil in the freezer thats iced up is blocked so when the defrost heater comes on and melts the frost from that coil,it the water is collecting in the freezer and in many cases drips into the fresh food compartment,clearing the drain will resolve your leaking/ice build up issue.THE DEFROST HEATER IS GOOD melting the frost in the first place and hence forth that melted frost stays in the freezer and becomec ice.
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
We have a TFX25JR side-by-side with ice maker and water dispenser; had water leaking on floor on freezer side of bottom left corner. Comes under tray, cleaned the coils and seemed to work, but 2 weeks...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
WATER FREEZES ON THE BOTTOM OF THE FREEZER
I have an LG armoire style fridge/freezer and it had lots ice in the bottom and would eventually drip onto the floor. The problem was with the defrost controller. The moisture that enters the freezer when it is opened condenses and freezes on the freezer coil/fins. There is a heating element that sits under this coil which gets turned on by the defrost controller to melt the frost/ice. As the frost/ice melts it drips into a metal tray which channels the water to a drain hole to have it drop into the drip tray underneath the unit for it to evaporate. The problem is that the before the water has time to leave the freezer, it freezes thereby plugging up the drain hole and thus causing subsequent defrost cycles to have the water flow into the bottom of the freezer where it freezes. Eventually the bottom of the freezer fills up with enough ice for the melted water to flow onto the floor. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
Sep 22, 2009 | Maytag Refrigerators
GE TFH27PRSA ice maker water fill tube and receving bucket on ice maker keeps freezing closed. No other problem with unit including water despenser to door. Once the tube freezes closed, water is leaking...
all is normal with the defrost heater getting red hot.
as far as the inlet tube freezing, you most likely need a new water inlet valve. it may not be closing all the way and water is slowly dripping into the icemaker and freezing up right away. a new valve should fix your issue. here is the part that you need. http://www.repairclinic.com/SSPartDetail.aspx?s=t-TFH27PRSA-%3d%3di1032629&PartID=1032629
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water collects and freezes in bottom of Kenmore freezer of side-by-side freezer/refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks!
Jul 15, 2009 | Jenn-Air JCD2295HES Side by Side...
Defrost Timer Prroblem?
Jul 08, 2009 | GE Profile PSF26NGW Side by Side...
Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Oct 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
174 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
