Question about Dishwashers
Cannot adjust the rear legs to the correct height.
  • 170 Answers
Is it that you cannot reach them? If so, pull the machine out enough to where you can get to those legs from the side and adjust them that way, then push it back in. There's also a 'kick plate' that can be removed allowing you more wiggle room to get back there with a wrench. Good luck!
Posted on Jul 18, 2008
How do I adjust the height of my whirlpool ingregrated dishwasher
Whirlpool dishwashers have 2 rollers on the back leg area. Some had extra holes to raise or lower the rollers somewhat by unbolting the rollers and moving them to one of the other holes. However you want to make sure the dishwasher is installed with a slight tilt front to back with the front higher. If you tilt it the other way it will probably result in a door leak. Make sure front is higher than the back.
Feb 15, 2015 | Whirlpool ADG8410FD_BK Dishwasher Full...
How do I adjust the leg height of my drafting table?
There should be screws/knobs at the table base. I've also seen these at the front legs of the table. You have to loosen the knobs, adjust the height and then tighten the knobs once you are happy with the height.
Jan 07, 2013 | Furniture
Leveling kenmore elite front loader
  • Place the level on the top of the washing machineicon1.png to see if it is level. Make sure you test it side to side and front to back.
    Pull the washing machine away from any walls if you have to make an adjustment to the legs.
  • Lift the washericon1.png and place the wood block underneath the washer. Place the block near the leg that needs to be adjusted, but don't let it obstruct the leg.
  • Loosen the nut that secures the legicon1.png with the wrench.
  • Raise the height of the leg by twisting it to the left, or lower the height by twisting it to the right.
  • Remove the block of wood from under the washer and recheck the machine with the level.
  • Raise or lower the leg if additional adjustments are needed.
  • Tighten the nut on the leg with the wrench when the machine is level.
  • Repeat the process for each leg that needs to be adjusted.
  • Move the washer back into position and check with the level again to make sure the washer remains stable to finish leveling the machine.
    Richard Roth
  • Nov 13, 2012 | Kenmore Elite 45986 Front Load Washer
    Are drafting tables one set height is can it be adjusted?
    Most drafting tables can be adjusted anywhere from 30 to 50inches in height. When purchasing adrafting table, it is important to confirm with the salesman that you have thisoption.
    May 29, 2012 | Furniture
    I am too short for my 125 r honda how do i adjust or can it be done.. Help???
    my mrs is just the same, measure the bike whilst you are sat on it. from the number plate to the floor and also a similar fixed point on the front to the floor (the most forward fairing bolt maybe) jack up bike rear end take a look at the shock mount on swing arm. un do bolt. move shocks position in swing arm bracket until you realise where if the holes where drilled it would secure and the rear wheel would be closer to the seat effectively lowering the rear. drill new holes. start with a small 3mm pilot and move up to i think 10mm was the size. make sure that you don't make these holes to close to the edge of the metal. drill speed real slow and lots of pressure. you are drilling metal and so you need less speed and more push like you are cutting not drilling. once complete refit rear shock bolt in new hole.sit on and take a new measurement of rear number plate to floor. write down the difference between old hight and new height. undo fork leg securing bolts. 10mm socket i think. slide leg up to match the difference on the back. retighten, do the other leg. make sure both legs measure the same!!! measure the front and rear. the rear may change slightly due to angles. readjust until correct. get a small amount cut from the middle of the side stand and have it welded together. ensuring the bike stands right. done, one happy shorty. enjoy.
    Apr 25, 2012 | 2006 Honda CBR 125 R
    Fitting details for Hotpoint LFT114 dishasher
    Hi when adjusting the legs just get it squair with the counter top keeing also level , it is ok if it tips towards the rear a little ,,once you get it set then install the two screws to keep it from moving ,
    Dec 10, 2011 | Hotpoint Dishwashers
    Adjust seat for 26mens huffy
    If it is a hand latch, pull out raise seat then push latch back in. If it is a bolt, then using a 5mm hex wrench turn it counterclockwise until loose. Do not remove bolt completely. Pull up on seat to desired height. Tighten bolt via turning it clockwise until tight. If it a mountain bike then while the pedal is at the bottom of the stroke you should have a 25-30 degree bend in your leg. If it is a road bike then you should have a 15-20 degree bend in your leg. If you need help choosing the correct height then go to your local bike shop with your bike and ask them to move the seat to the correct height.
    Jul 17, 2011 | Huffy Cycling
    I want to know how to fix the alignment on my 1995 honda accord ex.
    Before making wheel alignment adjustment, perform the following checks:
    1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
    2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
    3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
    4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
    5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
    6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
    7. Ensure wheel lug nuts are tightened to torque specifications
    Ride Height Adjustment
    Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
    Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
    Wheel Alignment Procedures
    Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
    Civic Camber Adjustment
    Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
    Civic Caster Adjustment
    DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
    Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
    Civic Toe-In Adjustment
    1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
    2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
    Wheel Alignment Specifications
    • Camber - Measurement in degrees.
      • Front: 0 (range -1 to 1)
      • Rear: 0.33 (range -1.33 to 0.67)
    • Caster - Measurement in degrees.
      • 1.17 (range 0.17 to 2.17)
    • Toe-In - Measurement in inches (mm).
      • Front: -0 (0)
      • Rear: 0.08 (2.0)
    • Toe-In - Measurement in degrees.
      • Front: 0.00 (range - 0.16 to 0.16)
    • Toe-Out On Turns - Measurement in degrees.
      • Inner: 41.00
      • Outer: 33.50
    Torque Specifications Ft. Lbs (N.m)
    • Rear Control Arm Adjusting Bolt: 48 (65)
    • Spindle Nut: 136 (185)
    • Tie Rod Lock Nut: 41 (55)
    • Wheel Lug Nuts: 80 (108)
    hope this helps you out.
    May 09, 2011 | 1995 Honda Accord
    I have a 90 series Kenmore washer, and I need to adjust the height of the back legs, but I do not know how to make the adjustment
    The rear legs are floating and self leveling. If one of them legs is all the way up in the base tip the washer towards you and yank out the leg to where each side is floating. Then ease the washer back down to the floor and she will level herself off.
    May 07, 2011 | Kenmore Washing Machines
    Spins off balance
    Hello kel_lyn_eve,
    Because your washing machine is so heavy, when it's not level, it can vibrate strongly during the spin cycle. If your washing machine is not perfectly level--with all four legs touching the floor--it can bang and rock back and forth, and even begin to "walk" across the room. This isn't good for the machine and may damage anything near the machine.
    Your washing machine has adjustable, front leveling legs with a lock nut. You adjust the leg to the proper height, then tighten the lock nut up against the body of the machine to keep the leg from rotating.
    Some machines have adjustable leveling legs in the rear also, and you can adjust them in the same way. Keep the machine as close to the floor as possible--the lower it is, the less likely it is to vibrate.
    Most machines, however, have "self-adjusting" rear legs. You set these legs by tilting the entire machine forward onto its front legs (with the rear legs 3 to 4 inches off the floor) and then setting the machine back down. The legs should adjust automatically. If they don't, you may need to tilt the machine forward and rap on the rear legs with the handle of a hammer to loosen them--a procedure that's easier to accomplish with a helper.
    Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Oct 12, 2008 | Washing Machines
    Dishwashers Logo
    405 people viewed this question
    Top Dishwashers Experts
