Question about Dell Inspiron 1300 Notebook
DELL INSPIRON 1300 DESKTOP ICONS and Taskbar flashes on and off gone most of time
Shortly after logging in my desktop icons and taskbar/ start menu disappear what do I do?
    Genius:
  • 2,028 Answers
Try a system restore if it will allow you. If not you may need to run a system repair with your recovery or operating system disc.
Posted on Jul 18, 2008
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Apr 27, 2014 | Panasonic Toughbook CF-51 Notebook
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
I have a computer with Windows 7. I can't see my desktop icons nor my start menu!
Right click on the desktop, in that window go to View in there Click on Shoe Desktop Icons in that same Window go down to Personalization in part of the Control Panel in there go down to the left hand Corner and there you will find Taskbar and Start Menu Click on that and Click on Lock the Taskbar and Taskbar Location on Screen: pick Bottom.
Feb 09, 2013 | E-Machines eMachines Desktop PC
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
My dell inspirion notebook starts up but only goes to wallpaper no icons or taskbar appear. Ive tried to reboot using f12 but it never goes to reboot it just restarts
hello, try this and see if it will be your fix.. when you are at your desktop right click and go to view and then select show desktop icons. This should bring everything up for you. If not let me know and we will go onto the next step.
Nov 10, 2010 | Dell Inspiron E1505 Notebook
My computer icon is not on taskbar and i dont have the disk to install it back
Restore Icons to the Desktop In Microsoft Windows XP Home Edition and Professional, the new Start menu is enabled by default. When the new Start menu is enabled, the My Computer, My Documents, and My Network Places icons are removed from the desktop. To restore these icons, follow these steps:
  1. Right-click the desktop and click Properties.
  2. Click the Desktop tab.
  3. Click Customize desktop.
  4. Click the General tab, and then click the icons that you want to place on the desktop.
  5. Click OK.
Nov 06, 2010 | Dell Dimension 2400 PC Desktop
My desktop Taskbar is gone!
Bring up the task manager. Click [File] then "New Task(Run)". Type "cmd" into the text field and press Enter. This will open the command prompt.
Dec 08, 2009 | Computers & Internet
My Dell Inspirion 1501 taskbar icons are turning white
scan your laptop...check with a good antivirus...
scan.................................
Jan 06, 2009 | Dell Inspiron 1501 Notebook
Taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
Dell Inspiron 1300 Notebook Logo
176 people viewed this question
Alun Cox
