Question about LG Televison & Video
Channel my 42 plasma TV channels dont fall in order for example. once my channel hit 13 channel the next channel will be 30. how could i fix this problem??
  • LG Master
  • 520 Answers
Check the TV(or air)/ CABLE(or catv) setting in the menu. Make sure it is set correctly.
Posted on Jul 18, 2008
I need to get my TV on channel 73 and i can't figure out how to do that
To get the tv on channel 73 you will need to use your remote that came with the tv. Type in channel 73 then hit ok or select. Or you can change the chanel buy using the channel button on the Tv.
Dec 26, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Whats causing horizontal lines in my philips 42 in. plasma tv? seems to be 4 sets of lines with about 15 to 20 lines in each set. Also has the red vertical explosion from images on the channel im watching.
There are very fragile ribbons that are attatched to the top of some LCD displays, if these have been pinched or damaged in anyway, this can create what you are describing. Was the LCD panel ever hit by like a wii remote around the tv bezel or did it fall without cracking the screen? It could be something simpler like, some really wrong color settings or something...
Jun 14, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
I can only get the first 13 channels. I am trying to program the plasma for viewing but I can not pick up any more channels.
In your channel setup menu there will be an option for air/cable selection.Right now you must be on "air", that why you get only the 2 to 13 channels
You want to select "cable" and then rescan/autoprogram your channels. Hope this will help .
Dec 02, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Ok so i bought a 42' plasma TV it on the manual it says i don't have to buy a converter box because i can just watch it downloading the channels it does work but is static and sometimes the channels don't...
Connect a antenna to the tuner that is for air and scan your channels for air not cablein the set up menue. Some channels may pixelate because of a weak signal.
Oct 14, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Very light colored verticle (1" wide) ribbon on LG 42" Plasma TV
The TV is design for 16:9 format. The bars appear when the TV off showing that the TV has been watching under channels which is have 4:3 format for long time. The screen was burn out because no sweepping to those area. This is not critical problem but you can do nothing to fix it. To eliminate it a bit you shoud read the manual, I believe it has mentioned how to roll or sweep the screen. For plasma TV, if you keep watching 4:3 channels fomat, you shoud do it one a month within 30'. Good luck
Aug 12, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Esa 42 in plasma.....out of range?
i have a plasma tv (china brand) when i start the TV the remote control for other devices are not working, only working if the remote is too close to the sevices or by reducing the brightness to its minimum level (zero level..no brightnesss)
i need help strange fault
May 05, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Service mode for hi sense tc3418uf
Hit the menu button. By hitting the volume button once you will see a menu to adjust TV. Click down by hitting channel to TV frame. Click adjust volume.
Oct 30, 2008 | Hisense TA42P40M 42 in. Plasma Television
Sansui 5000x
I am guessing this is a freeview channel that you are having issues with ?
Perhaps a re-scan for channels may solve the problem or the channel may not be free, it may be topup tv channel. UKTV Gold is an example of this. What is the channel in question ??
Jan 27, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
TV changes channel changed before all numbers entered in remote
Possibly you're not hitting the numbers fast enough or there is a problem in the delay circuit in the microprocessor. Stargazer
Mar 02, 2007 | Zenith H32G48S TV
Televison & Video Logo
53 people viewed this question
Computer Repairing
Computer Repairing
