Question about GE A830 Digital Camera
My lens wont work.
I turn the camera on and the lens comes out but then right away it closes and it says lens error. It's not like i dropped it or hit it or put it in water, so i don't know what to do. How can i fix it?
  • 1 more comment
  • hiandfast Jul 27, 2008
    When I turn the camera on, the lens comes out and then retracts, the screen says "lens error" and then it shuts off. I have tried new batteries and taking out the memory card and tried all the settings on the selector dial on top.
  • Anonymous Sep 11, 2008
    I don't know what to do, can someone help me please??
  • cowgirl2u Oct 13, 2008
    my camera is doing the same thing. Can some please help
  • 153 Answers
The camera is defective. Call 800 730 6597 and if it is still in warranty, we will send you a form to fill out and have you return the defective camera and then ship you a new one.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Posted on Oct 28, 2008
4 Suggested Answers
SOURCE: Lens wont close.
my camera says the same thing. i dropped it and now it won't close or start or open. how do i fix it?
Posted on May 11, 2008
  • 373 Answers
did you try and take the battery out and outting them back in
might be worth a try
Posted on Feb 08, 2009
  • 668 Answers
SOURCE: dropped camera now lens wont close. It says lens
Remove the batteries and insert new batteries . Sometimes this may work but in your case the lens is stuck inside, or it will have been damaged . Nothing can be done other than taking to service center to get it repaired .
Hope this helps .
Posted on Dec 16, 2009
I turn on my camara and then the lens makes a noise and it turns of right away,i charge the battery (fully) and it still turns off
maybe because you have a lens error trouble, Lens errors (system errors) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:wish you luck thanks
Feb 21, 2012 | Sanyo VPC-X1250 Digital Camera
Hello i dropped my lens the other day and the auto-focus doesn't work. it does but its like i have to be close and even that at times wont work. the manual does work. before i purchase another lens, i...
I think you would be further ahead by replacing the lens, the corrections for lens errors works best on small camera's and it is risky. The only thing you can try is gently extend the lens manually and power up at the same time in an attempt to align the guides in the lens housing at the maxium extension, if it works the lens will retract when the camera is turned off. The other possible solution is, extend the lens and sharply hit around the lens housing with the palm of your hand and hit power at the same time, "very risky" but this might be enough to knock it back in position, but please note this can make it worse.
Mar 07, 2011 | Nikon D40x Digital Camera
Dropped camera now lens wont close. It says lens
Hope this helps .
Dec 16, 2009 | Canon Cameras
Canon PowerShot A640 lens problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 31, 2009 | Canon PowerShot A640 Digital Camera
LENS ERROR
You are basically right. Its basically as easy to replace as it costs to repair, unfortunately those are your options. You could inquire as to an estimate to make your decision easier, or locate an independent repair shop as they may be cheaper. The camera would need to be taken apart and I only recommend that if you know what your doing.
Thanks,
Lee
May 27, 2009 | Nikon Coolpix S210 Digital Camera
Lens error, lens wont come out at all just started wasnt dropped hit or anything
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 27, 2009 | Sanyo Vpc-s1070w Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Lens error !
I had the same problem. I dropped my camera on the floor today while its on. I tried hitting it but it didn't work. So what I did is, I pull the lens or shuttle forward then I close it and turn it back on. It work perfectly fin now. I hope that helps.
Feb 01, 2008 | Nikon Coolpix 5200 Digital Camera
Nikon Coolpix L12 It has a constnat lens error screen
mine has that too....urgh i need to take pics cuz im going on vacation too....joy
Dec 31, 2007 | Nikon COOLPIX S9 Digital Camera
Indication E:62:10
I had the same error- I tried wacking it against my leg- and now it works again!!! thank you!
Sep 28, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
GE A830 Digital Camera Logo
77 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Are you a GE Camera Expert? Answer questions, earn points and help others
