Clean d.c blade of drum , laser then check teflon in fusing unit
You have to open the hatch of the printer and take out the cartridges. The problem that you are facing is because of the leakage in the cartridges. Examine the cartridge bodies carefully and also look at the cart which carries the cartridges carefully. You will definitely find traces of congealed ink. You need to clean the cartridge body and the cart with cleaning liquid. If you have spirit (Alcohol) or White Vinegar it also works well. Moreover also look around the cartridge cart where you can reach inside the printer for cleaning.
If you do that you will find the difference because the cartridges are the only source of ink. You can also try changing the cartridges.
Good Luck!
