Question about Whirlpool Dishwashers
Hi i have a whirlpool 6adp951-3awh dishwasher that wont fill up i was told it could be the valve close to the tap
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
Whirlpool dishwasher error code F6
F6 error fault code
This is the Water tap closed. What that means is that the flow meter is not recording water entering the dishwasher, this can be a water tap turned off (suprisingly more common than you'd think, after new flooring or decorating has taken place),
water hose kinked or blocked, the dishwasher water soleniod valve defective.
Nov 10, 2016 | Whirlpool Dishwashers
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
Aeg favorit dishwasher not filling with water
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
Sep 05, 2014 | AEG Dishwashers
My whirlpool dishwasher wont get water to it when I press start
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Sep 16, 2011 | Whirlpool Dishwashers
What to do if whirlpool awz 50e washing machine is showing water closed tap indicator although tap is not closed
Providing that the tap is turned fully on and the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Mar 27, 2011 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool dishwasher doesn't clean very well
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Whirlpool Dishwashers
Start light flashes 6 times
6 'start' led blinks indicates
WATER TAP CLOSED
Water walve is switched on but flow meter sends no impulses or sends less tan 10
impulses in 10 seconds and the water indicator is off (empty)
posible reasons:
water tap closed
water inlet hose closed
water inlet valve defective
flow meter defective
remember to unplug it from power if any repair is done
Best regards and good luck
Oct 04, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Dishwasher fills with water by its self.
yes you do the valve is very easy to replace located
at the bottom left of the d/w make sure to shut that power off
Apr 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwasher wont fill
I fit won't fill then apparently you're not getting any water to it, which means it not's fixed. Did you turn the service valve back on since the repairs were made? Sometime when you turn a service valve off they fail to re-open. Crack the inlet water line and verify that you have incoming water.
Jan 18, 2009 | Whirlpool 24 in. DU1050SS Built-in...
Dishwashers Logo
135 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
