Question about SanDisk Sansa Clip MP3 Player
Sandisk clip Is itmacintosh compatable..was working fine just got an new apple lap top plugged it in to charge and now the light pops up cannot move around in menu..just says sandisk and buttons do nothing..is there any hope in salvaging this
  • 8,596 Answers
Not Mac compatible
Posted on Aug 14, 2008
How do i create different playlists in my sandisk sansa clip. It will play all it will play albums. I have tried to drag a playlist from the lap top windows media player but it says it needs converting to...
1) Open the Sansa in 'My Computer'
2) Double click on the 'Playlist' folder
3) Drag the music you want from the computer into the 'Playlist2_bing.gif' folder
4) Highlight all the files (or the files you want)
5) Right click
6) On the menu that pops up click "Create Playlist" - on my computer it's the very first option, in bold
7) Playlist will be created in the 'Playlist' folder
8) Name it whatever you want and enjoy!!
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
Took my hard drive out of my pc lap top because the mother board is fried and i bought the aluratek hard drive cover with usb connecter and mac compatible hooked it up to my mac lap top to transfer files...
The smart bit is irrelevant but you should be able to transfer your files off it OK.
I don't know how mac familiar you are but all you have to do normally is plug the drive in to a convenient USB port and plug in some power. (Some drive cases that don't have external power need to plug in to the computer with a special lead that has 2 USB clugs on one end.)
After 5-10 seconds the drive should pop up on the desktop, you can then open it and copy stuff off.
Where does this pop-up come from as I've not experienced one in years of Mac support.
Dec 21, 2009 | Computers & Internet
Sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip MP3
Go into My Computer and see if anything pops up once you plug the Sansa in. If it pops up open it up from there. Sometimes this kick starts an Mp3 to install itself.
Apr 01, 2009 | SanDisk Sansa e200 MP3 Player
Wondering how long it takes to charge the Sansa Clip MP3?
I have had the same problem. It seems the radio never turns off and keeps drawing power. Solution: before charging, go to a song, start it playing, then pause it, then turn off the sanza clip. Plug it in and it should charge up fine.
Mar 22, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip Won't take a charge...
Are you sure the cable you are using provides both data and power to the device? Some cables are data only and will not charge the device despite appearing so.
Has it held a charge before? If this is a new device and has not yet ran down then charged fully again yet, then I would return it.
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk will not turn on
Surprisingly the solution was quite simple after I stopped panicking. The Sansa Updater Setup Maintenance Program, I don't know where I got it from, probably off the web site for Sansa. I clicked it, followed themessage to delete current files and update new material. It told me to plug in my "dead" Sansa Clip (which was full of audio books I did not want to loose) and like magic it came to life. I sure hope this information helps someone. I have the silver 4g SanDisk and LOVE it
Sep 30, 2008 | SanDisk Sansa Clip MP3 Player
Was fine now dead
Hello jessisme,
What you describe sounds like either a battery problem or a hardware failure. I would recommend trying to charge the unit following the normal charging procedure listed in the manual.
If the unit will not turn on at all after charging then most likely the battery has failed or the or unit has some other hardware problem that will require service. If this is the case, I'd recommend contacting the manufacturer via their website at http://www.sandisk.com/techsupport for additional support.
Best regards,
Ken
Go Ahead. Use Us.
May 07, 2008 | SanDisk Sansa Clip MP3 Player
Photosmart 3310 is on network but not recognized wirelessly
Sounds like another Vista Bug, i would check the HP site for this issue and if its under warranty, contact HP. If you have alot of Blue tooth devices hooked up, it may be that its trying to use another device in its place or the signals are getting crossed, im not positive.
Its like when you have to many network drives all hooked up and you plug in a USB device, Windows pops up those anoying bubles saying its detected, but in My computer it doesnt show.
So bassically you have to right click my computer, manage, disk management listed uder storage, right click on the device or drive and change the drive letter to something like " W" or " Z" or anything not in use.
It may be a siomilar case with your bluetooth, youo may have to much stuff connected. Try redoing everything like you have so many other times before, and then limiting how many bluetooth devices you have connected at the same time. see if theres a difference.
Hope this helps.
Dec 25, 2007 | HP Photosmart 3310 Printer
Sandisk cruzer micro 2gb not detected
sounds to me like its fried. Have you tried using it on another machine? If its only 2 weeks old you can call sandisk and get a new one.
Oct 25, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Sansa Clip MP3 Player Logo
117 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
