Question about HP OfficeJet 6110 All-In-One InkJet Printer
Power light dims when inserted into 6110 xi won't turn on
I have a very strange problem with the HP 6110 xi, in that the small green light at the end of the power cord is bright green when removed from printer but when inserted into printer it dims or seems to rapidly blink.  Printer will not power up.  Any suggestions??
Spoke with HP support...they said software program and printer out of warranty so a new one was purchased....am I a ******?
Thanks
Posted on Jul 18, 2008
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
Mar 19, 2012 | ASUS (X83Vb-X2) PC Notebook
Officejet 6110- do display/needs attention light on continuously
try this
turn on/off, unplug, plug in, should reset configs. might have to do this a coupe of times
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
hope this helps and good luck
Apr 28, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How do i change font size on HP 6110 xi printer
The manual doesn't list scaleable font size as a feature. You will probably have to set your font size in the document you are making.
Mar 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6110 xi All-In-One will not scan
This is an interesting problem because a printer isn't "intelligent" the way a computer is "intelligent". While devices such as the 6110 have RAM and thus "memory", they don't have the ability to recognize which devices are connected to it, as such. That's why you have to install all of the HP software and drivers onto the Windows or Mac machines, so the burden of recognition and interfacing is on them.
That said, information and even errors can be stored in a printer as long as it's receiving power...sometimes even when they're turned off.
My first suggestion is to completely turn off the 6110 and unplug it both from it's supply of power and from any computers.
Let it set for around 30 seconds to a minute so that any residual power from the "brick" dissipates.
Reboot the Windows computer.
Then plug the 6110 back into it's power supply and attach it back to the Windows computer.
Power up the 6110 and let it go through it's start up and alignment routine.
Try to scan again as you originally did before you tried to us your Macbook with the 6110. Hopefully that will do it.
If, for some reason, the Windows machine is still not able to interface with the 6110, you may have to completely uninstall all of the HP software and drivers from the laptop and reinstall them using the original installation CD, just as if you were installing the printer with the laptop for the first time.
This means (assuming you have Windows XP), going to Start -> Control Panel -> Add or Remove Programs. You'll need to go through the list after "Add or Remove Programs" opens to select and uninstall all the software and drivers that have anything to do with the 6110. Hopefully, this'll be just one or two selections.
If you have the original CD, you can also insert it and it should offer you the option to uninstall the original software and drivers. That would be the easiest. Then you could just turn around and do a reinstall from the disc, no muss, no fuss.
If you do not have the original CD (and believe me, these things get lost all the time), you can still download all the latest software for the 6110 onto the Windows laptop by going to this web page at HP.com:
Officejet 6110 Software and Drivers
Once you go to that page, you'll need to select your particular Windows operating system name. You'll be taken to the web page where you can download the installation software and the latest drivers. Once they're reinstalled onto your system, you should be good to go.
You "may" be able to install the latest software and drivers without uninstallng the old stuff first (that is, you could be offered the option to overwrite the old software when you install the newer software),. but that's not as "clean" and instead of curing the problem, it could make it worse. If you're a risk taker, go for it. If not, don't take the chance of more headaches.
I probably made this sound more complicated than it is. Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning
Try using the scan program provided by Hp already installed in your computer.
Double click on "My PC" select the OfficeJet scanner icon and do a the right click, and then order to a scan.
Oct 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer problem
hi,
have you tries inserting new set of ink cartridge???
try this...
> unplug the power chord.
> remove the rear access door.
> check for any jammed paper. if so remove it.
> clean the rollers using a lint free cloth.
> close the rear access door.
> keep pressing the on button for 20 seconds
> try to copy
if no go
> unplug the power chord while it is turned on
> remove the cartridges
> press and hold the ok and cancel button at the same time.
> while holding them insert the power chord, and wait for few seconds and then release your hands.
> when it asks for the ink cartridge, insert them ad check.
if no go, contact me
thanks and regards
agnel
Mar 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
114 people viewed this question
Seeker5211
Seeker5211
