Question about Coby TF-DVD7333 Portable DVD Player
Not reading disk
Everytime i put a dvd in my COBY TF-DVD7333 it says that there is NO DISK in when there is. It makes a little noise but doesnt read any disk. Please help, got an angry 2 year old who needs his Disney. Thanks
  • 2 more comments
  • Ill Mill Jul 18, 2008
    tried that but it still didnt work, the disk all also not spinning at all. I "reset" by taking the battery off for 30 mins but that didnt work either. Thank u for your help AlmostBob
  • Ill Mill Jul 19, 2008
    Ok now its starting to spin when i close the lid but its still not reading the disk. Is the motor just fried and i am SOL or is the another solution possibly? Once again appreciate your help. Thank u
  • Anonymous Feb 16, 2009
    my dvd player is not loading any disc
  • alex_samuel Feb 16, 2009
    alignment of my dvd player (COBY TF-DVD7380E) laser not in proper way so please give me proper lsolution with drawing.
  • 550 Answers
Dirty lenses on the drive can cause this, no signal comes back to the laser, so it thinks there is no disk
especially with kid fingers and a flip open case,
iso-propyl alcohol on a swab removes fingerprints, jelly, cake, and all sorts of stuff from a lens, vaccuum cleaners are good if its just dust
Posted on Jul 18, 2008
  • 1 more comment
  • AlmostBob
    AlmostBob Jul 18, 2008
    the disk not spinning is the problem, causing no read, that wasnt mentioned in the op so there is a different repair
    there is something stuck in or under the spindle preventing the motor from bringing the disk up to speed, the seizure could have fried the motor.
    Thin flexible plastic, I use margarine container lids cut to points, is usefull as it can often be slid under the drive spindle without disassembling the drive and flick the cookie crumbs out.
  • AlmostBob
    AlmostBob Jul 23, 2008
    unless there are cookie crumbs under the actuator that moves the lens to the start position (center) then follows the data track out -
    Im stumped,
    Have had good results with fish tank air hose attached to the vaccuum cleaner for access to small holes
  • AlmostBob
    The drive typically looks something like this opened
No picture and no sound on dvd7333
Hello
The backlight inverter board of your TFT is faulty. Soemtimes the CCFL tubes have the trouble. Anyway, there is no backlight coming up. Check for it. OK.
Dec 15, 2011 | Coby TF-DVD7333 Portable DVD Player
I have a coby vzon that says wrong disc but reads cds then when cleaned and blown loads up mp2 instead of dvd or says wrong disc still please help.
All DVD players use a dual laser pick up. One laser is for CD/VCD/MP3 and the other laser is only for DVD. If you have watched more DVD and less CD's you could be having a problem with the DVD laser. Must have become week and the system cannot read the disk. Change of the lens unit will solve your problem.
Mar 10, 2011 | Coby TF-DVD7107 Portable DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
The player will play commercial disk but will not read blanks to record
the problem is that your portable dvd player is not a recorder. its just a player that is capable of reading already recorded dvd's.
Feb 21, 2009 | Coby TF-DVD7006
Error says no disc
wrong disk Usually means the lense is not reading the dvd, if you tried more than one dvd then the lense is dirty or bad
you can get an out of warranty replacement because coby doesnt repair these:
Send:
$31 Money Order - made out to 'Coby Electronics
Note with your Name, Address, Phone#, Description of Problem
Unit with all the accessories
Send to:
Coby Electronics
Att: Customer Service
56-65 Rust St
Maspeth, NY 11378
Turn around timeframe is 2-3 weeks.
Aug 01, 2008 | Coby TF-DVD7100 Portable DVD Player
What is the hack to make dvd player (portable) coby tf-dvd7333 multi region?
Press SETUP
Press FF
Press FR
Press Next
Press Prev
now region code will appear on the screen on the right upper part of the screen
press -> the arrows to chancge the number to 255 to make it open region.
Jun 18, 2008 | Coby Televison & Video
Coby TF-DVD7100 7" portable flat screen...keep getting "Wrong Disc" Error
I have seen this problem on several Yamada & Xoro brand DVD players. If you remove the lid after powering down with the disc tray closed and a disc in it you may well find the ribbon cable to the read head is rubbing on the disc. The ribbon cable is held to the base of the box by a sticky pad under a 45 degree bend in it and a piece of sticky tape !!!. Power up unit, open disk tray, power it down, retape cable to base securely with small strips of duct or gaffer tape (using tweezers helps) and hey presto it will work again. The cable rubbing slows the disk spin speed hence "data read error" unit assumes "bad/faulty/wrong type of disk". All that technology screwed up by using a cheap bit of tape in the factory assembly, amazing eh !.
Mark
Mar 02, 2008 | Coby TF-DVD7100 Portable DVD Player
SAYS "NO DISK"
sounds like the laser doide has failed, and may not be practical to have repaired. D-Dan
Aug 25, 2007 | Coby TF-DVD7100 Portable DVD Player
Can't read DVDs
were you able to fix your dvd tf-dvd7100? i have the same problem with this unit.
Aug 24, 2007 | Coby TF-DVD7100 Portable DVD Player
Why black and white????
Black and White on all discs? Display controller or cable to LCD. Replacement is cheaper than the parts.
Aug 01, 2007 | Coby TF-DVD7333 Portable DVD Player
Coby TF-DVD7333 Portable DVD Player Logo
257 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
