Question about SanDisk Sansa m240 MP3 Player
Computer not recognizing my sandisk m240 mp3 player.
I have windows XP, and my sandisk m240 mp3 player is not working, i cant burn music to it, its like the player isnt even connected but it is. I used the installation CD Easy Start and all it did was download a updated version of Windows Media Player. If anyone knows what im doing wrong please email me at Also I have a Centrios Mp3 player and that works perfectly, so i dont understand why my computer is not recognizing my Sandisk...please reply if u have a solution... Thanks .......
  • 758 Answers
What I would recommend you to do is to make sure that your device is under MTP mode instead of do that go under menu,setting, usb and then there should the two mode listed there...then you want to plug your device in the back of your computer..not in the front..tghat is very important....once you do up your windows media on your start thee sync panel..if your device is recognize properly it will be showing there on the right side..and if its not listed properly, it will say connect a device..if thats the on your start menu right click on computer and then click on propetties, click under hardware and then device manager..your device should be showing there...check under disk drives to see if your device is showing there and if it doesnt you want to right click and hit uninstall...we dont want your device to be under disk drive ..we want it to be under windows portable device...once you uninstall it...go to and find the driver for your device..and then connecct the device on the back of your should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Posted on Jul 18, 2008
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
How do you delete songs off of a sandisk sansa m240 music player
In My computer right click on the mp3 player and select format..then it will delete all songs..
Feb 27, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240
i have the same problem but i believe it is because of one computer using Fat32 file system and another using NTFS the only way i can think to fix it with out reformating is to make a FAT32 File partition on your computer so windows can operate in that environment for example if you used windows 98 to put music on this thing and then try to view it with XP the file systems are different and cant be recognized. you can make a back up of the system files for it on the computer. Format the device and then when you save NTFS files to it your new computer will recognize it. Im just trying to make sure that if i format the drive i wont lose the operating system on he mp3 player
Jul 27, 2008 | SanDisk Sansa m240 MP3 Player
Stuck in "sandisk initializing screen"
To those that are having problems with the MP3 player not being recognized. With Windows XP there is a little Icon on your Systems Tray that is called the "Safely Remove Harware Icon". Not using this Icon when unpluging MP3''s or zip drives can cause your PC to no longer recognize it. Toshiba Satellite laptops are known for this, others probably have the same problem. The solution here is to install the latest update of the ACPI Flash Bios for the Toshiba Satellite computer. Maybe this is also the problem with other PCs. To prevent these problems allways click on the Safely Remove Hardware icon before removing the MP3 player or any USB flash drive
1 With your m240 set to MSC and connected, go to "My Computer" and "right click" on the "Sansa m240" icon and select "Properties"
2 In that window, select the "Hardware" tab
4. In that "All Disk Drives" window, highlight the "Sansa m240" drive and select "Properties" (at the bottom)
5. In that window, select "Policies"
6. And there, set it to " Optimize for Quick Removal" and click OK and OK again
Dec 02, 2007 | SanDisk Sansa m240 MP3 Player
How to download the software of SanDisk Sansa m240 MP3
Sep 05, 2007 | SanDisk Sansa m240 MP3 Player
Its not plug and playing Sandisk 240m 1g
Hi blackmajik, I just got a Sandisk m250. Windows wouldn't recognize it either until I updated my Windows Media Player to version 11. Now XP sees it just fine and the MP3 player syncs with WMP and accepts and plays music!
Jun 07, 2007 | SanDisk Sansa m240 MP3 Player
Recognise my sansa
to old for vista to recognize
Apr 29, 2007 | SanDisk Sansa m240 MP3 Player
No drive appearing in My Computer
Device is not being recognized and is apparently incompatible with your XP OS installation.
Apr 16, 2017 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
