Question about Car Audio & Video
I have a electric radio antenna from a 1987 buick regal the nylon string with a metal cable inside used to extend and retract the mast is broke into if i could a new piece i could fix it. walt
  • 1 more comment
  • waltace1952 Jul 19, 2008
    I don't need a mast i need the cable that pushes the mast up and pulls it down it looks like nylon from a weed trimmer except it has a cable embedded in the center. Thank you. Walt.
    Is there antenna mast makers that i could contract ? Walt.
  • waltace1952 Jul 21, 2008
    there are no teeth on the nylon string it is round and smooth like a weed trimmer has only there is a metal cable in the center of this the design must of changed.walt.
    Scholar:
  • 91 Answers
Yes it is possible to replace just the mast/antenna part. You just need to goto a car audio place and get an replacement mast. The only other problem is if the the other half of the nylon piece is still stuck in the motor.
Take off the antenna nut that holds the antenna to the car and turn on the radio. The antenna should spit it's guts out, then position the new nylon lead in the same orentation that the old one came out, have an assistant turn off the radio and the antenna should get sucked back in. You need to be somewhat quick when doing the replacement part, sometimes you need to try a couple of times to get the antenna all the way in.
If it doesn't go all the way down there may be a piece of the old nylon string still stuck inside the antenna body.
Posted on Jul 18, 2008
  • Jim  K
    Jim K Jul 19, 2008
    The replacement antenna mast comes with the nylon cable, you can't just replace the nylon cable part.
  • Jim  K
    Jim K Jul 20, 2008
    Your best bet is to goto the local car audio shop with the broken mast. If they have replacements in stock you can match them up. It mostly depends on the spacing of the teeth on the nylon part and the diameter of the mast, and somewhat the length of the whole thing.
    At the very least, if you have the skills, for a few dollars more you can replace the whole power antenna with an new aftermarket one. The additional benefit is that you can get replacement masts from the manufacturer if the antenna gets damaged again.
Need to know how to remove a regular antenna from a 1996 Toyota Tacoma. It is not a power antenna.
Toyota Pick-ups/Land Cruiser/4Runner 1989-1996
Antenna - REMOVAL & INSTALLATION
If your antenna mast is the type where you can unscrew the mast from the fender, simply do so with a pair of pliers. Most damaged antennas are simply the result of a truck wash or similar mishap, in which the mast is bent.
Manual Antenna
  1. Disconnect the antenna cable at the radio by pulling it straight out of the set. Depending on access, this may require loosening the radio and pulling it out of the dash.
  2. Working under the instrument panel, disengage the cable from its retainers.
On some models, it may be necessary to remove the instrument panel pad to get at the cable.
  1. Outside, unsnap the cap from the antenna base.
  2. Remove the screw(s) and lift off the antenna, pulling the cable with it, carefully.
To install:
  1. When reinstalling, make certain the antenna mount area is clean and free of rust and dirt. The antenna must make a proper ground contact through its base to work properly.
  2. Install the screws and route the cable into the cab. Make certain the cable is retained in the clips, etc.
  3. Connect the cable to the radio; reinstall the radio if it was removed.
Power Antenna Mast
The power antenna system contains a relay. If the power antenna is inoperative, the relay is the first place to look. The actual motor rarely fails.
The power antenna mast is replaceable on the Pick-Up and 4Runners. If the mast is damaged or broken, proceed as follows:
  1. Perform this repair with the battery cables connected. Turn the ignition switch to the LOCK position.
  2. Remove the antenna nut.
  3. If equipped with a CD player, press the AM and FM buttons on the receiver and simultaneously turn the ignition switch to ACC .
  4. For non-CD player units, press the AM button and simultaneously turn the ignition switch to ACC .
  5. The antenna motor will run, unwinding the mast from the spool. have an assistant guide the mast so it doesn't fall and damage the bodywork. When fully extended, the mast will be released. Remove it, and leave the ignition in the ACC position.
To install:
  1. Insert the new cable so that the teeth face the rear of the vehicle. Feed the cable into the motor until the cable reaches the bottom, about 12 in. (30cm).
  2. Have an assistant ready and prepared to guide the cable. Turn the ignition switch to LOCK . The motor will run, winding the cable onto the spool and drawing the antenna down into the mount.
  3. If the cable does not wind, twist the cable at the top of the housing; the part at the bottom may have turned while being pushed down the hole.
  4. Once wound onto the spool, install the antenna nut even if the antenna is not fully retracted. Test the antenna elevation and retraction; the mast will eventually retract fully.
Hope helped with this (remember rated this post).
Feb 26, 2010 | 1996 Toyota Tacoma
What is the easiest way to extract and replace a fixed antenna and wire from my 96 Cierra?
If your antenna is of the electric type, mounted into the vehicle's body, then it is more common to replace the MAST only.
This is done by:
- loosen & remove the upper locking ring (between antenna & vehicle body),
- turn radio to ON. This will unwind the antenna & cable fully (if cable has teeth, note direction which cable is facing).
- feed replacement mast cable into cavity (ensure cable is facing same way as when it was removed) until cable stops feeding, and hold in position.
- turn radio power off. Cable should grab & begin to retract. Guide the new mast into position. As cable feeds in, the mast will follow and retract to its closed position.
- secure upper ring
Cheers,
"if the above information has helped you in any way, please rate this solution"
Jan 27, 2010 | 1996 Oldsmobile Cutlass Ciera
On a Panasonic radio/cassette player model-CQ-RD910 Len,which colour wire is the trigger/sender wire for an electric aerial/antenna to extend or retract the mast. The electric aerial/antenna drive motor...
The " Blue & red spotted " wire that is spare from the rear of the radio transpires to come from the " cold " side of the radio's on / off switch , and serves to be only energized when the radio is switched-on and slowly shuts down on supply voltage when the radio is switched off , thus giveing a supply voltage for the relay & switch over reed switches in the aerial / antenna motor unit for a short run-down-time , to change over and allow the aerial mast to retract , in readyness for when the radio is switched on again and the aerial/antenna mast will power up .
This trigger / sender wire is connected via a 2 amp. fuse through to the aerial / antenna power relay.
The main aerial power motor unit is fed via a 6 amp. fuse.
Dec 12, 2009 | Panasonic Car Audio & Video
Power antenna broke and I need to replace it. How
Buy replacement antenna mast. Remove old one by unscrewing the retaining cap nut. Turn on the radio & let the antenna cable run all the way up while you pull on it to remove it.
Install the new antenna mast by turning the radio 'off' so the spool inside goes back to its beginning while you feed the cable of the new antenna down into the antenna mast hole.
Once the cable is all the way down, reinstall the retaining nut/cap and turn on the radio to allow the spool to run the antenna 'UP.'... cycle the radio ON and then OFF several times allowing the antenna to move all the way up and all the way down.
That's it!
Sep 28, 2009 | 2001 Hyundai Sonata
Antenna motor has a very loud grinding noise. Antenna won't go up or down
THE ANTENNA MAST DRIVE CABLE IS BROKEN, EITHER REPLACE THE ANTENNA OR THE DRIVE CABLE, CALL THE DEALER TO SEE IF A ANTENNA MAST KIT IS AVALIABLE FOR YOUR CAR, MUCH CHEAPER THAN A WHOLE NEW ANTENNA..
Jul 09, 2009 | 2002 Mitsubishi Montero Sport
Problem removing broken antenna mast
you have to pull out the trunk interior trim panels on the left side to access it.
there will a few 10mm bolts and a connector.
May 07, 2009 | 2006 Hyundai Sonata
I can hear the sound of the motor but the retractable antenna of the car radio do not work.
Try removing the motor and replacing. But before that try to see if it will come apart and check to see if parts inside are loose or striped.
Apr 09, 2009 | 1996 Toyota Camry
Electric Radio Antenna on 1994 Toyota Celica
Reverse the wires, one is hot going up and the other hot going down, the easiest way to deal with this is to just reverse them.
Nov 29, 2008 | 1990 Toyota Celica
Installation of vt holden commodore aerial rope and mast
You access the ariel via the left hand wheel arch.
1. Remove left wheel mud guard. It is held in with a bunch of press studs which can be difficult to remove. I found pulling on the plastic mud guard whilst turning the screw helped.
2. unbolt the electric ariel assembly. There is an earth strap that needs to be unscrewed as well.
You should be able to get the ariel out far enough to work on it.
3. Remove chrome plated nut to top end of mast tube.
4. With great anger and force, remove the dead ariel and drive cable from the mast.
It's difficult to get the mast to work unless it's earthed properly.
5. Get you hand inside the wall and remove the ariel face plate. Swear if you have to.
6. Put the ariel mast assembly back into the wall and hook it all up minus the new ariel.
7. Switch your radio on, then put the new ariel into the mast. Gears facing the rear of the car. Switch the radio off, it should retract. If not you may need to push it in a little further.
8. Remove the ariel mast again and slip the chrome nut to top end of mast tube and tighten securely.
9. Ask the spouse to close up whilst you have a beer.
Apr 03, 2008 | Car Audio & Video
Car Audio & Video Logo
103 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
