Question about Garmin StreetPilot c340 GPS Receiver
Garmin gps I have a garmin gps (street pilot c340) that is not turning on whether charged completely or not . It has not been damaged or dropped and is always kept in the glove compartment of my car. I went to use it and it has not been able to be turned on. It once came on briegly and then just blanked out. What may seem to be the problem.?
  • 2 more comments
  • elysmom Jul 18, 2008
    Ok, so how do I get the battery working properly. Or do I need it repaired. Is there somewhere I can take it to work properly. Or leave it out to air in room temperature to see if it may work...
  • laineydee Aug 30, 2008
    My Garmin 760 will not power on. I've tried leaving it on the pc hookup, on the car charger and on the dc charger. What else can I try?
  • azkyote Sep 06, 2008
    my street pilot c340 is about 2 years old.  It has worked perfectly until a week ago.  While plugged in to  my truck's 12v receptacle, I push the on button and it flashes on for abot two seconds.  If I hold the on button, the screen lights up, but as soon as I release the button, the screen goes black.  I have charged it for four hours.  Any ideas?
  • js0426 Sep 27, 2008
    Not turning on. Held the reset button for 30 seconds then tried to turn it on still nothing. the product has barely been used. Worked about 4 months ago. It is not registering a charge and is hooked into the computer. What shall I do?
Thanks moocows1 !!
The reset did it. To take the front frame off, insert a fingernail in a notch at the top center of the display frame.
Posted on Sep 28, 2008
I had the same problem with the unit not turning on. there is a master rest button behind the front shield remove the small plastis strip from around the front area and on the right there is a reset button hold it for 30 sec and try it again . it worked for me.
Posted on Sep 03, 2008
  • 504 Answers
Keeping the unit in the glove compartment is not a good idea, for a couple of reasons. If anyone suspects you have the unit, the glove box is the first place they will look. Secondly, it gets very hot/cold in the glove compartment, depending on the ambient temperature. It is not good for the unit, or the battery, to be subjected to extremes in temperatures. It is possible the battery is no longer working properly as a result.
Posted on Jul 18, 2008
  • Kevin Miller Jul 18, 2008
    Give the unit time to reach room temperature and try it again. If it still doesn't function properly, you should contact Garmin about replacing the battery.
Can the touch screen on my garmin c340 gps be replaced?
Yes, it could be easily replaced. If you want to purchase only touch screen, buy it from :-
http://cgi.ebay.com/GARMIN-C340-C-340-Street-Pilot-Touch-Screen-Digitizer-U-/270622808154?pt=PDA_Accessories&hash=item3f0260585a
If you wanted to replace LCD screen as well, buy it from :-
http://cgi.ebay.com/LCD-Screen-Touch-Digitizer-Garmin-C340-U-/120457660971?pt=PDA_Accessories&hash=item1c0bd60a2b
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 27, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin 340 street pilot
Remove the battery out and put back in after 5 minutes to reset it.
, check also that the in car power cable is working, and the Garmin is not drained. Tru to connect it to power outlet if you have an adapter
Mar 29, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Street pilot C340 has always worked. This morning it did not turn on. I relpaced the fuse in cord. Any other ideas?
Try charging it from the WALL charger. The battery inside the unit may not be too great. Try it - over night from the WALL charge -not the PC charger. 8de415c.jpg
May 04, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot c330
You have to pry off the silver-colored faceplate from the unit and you will find a reset button on the right side of the screen. Push this and everything will back to normal.
Oct 24, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Street Pilot C340
The only way to update the maps is to purchase new maps from Garmin and download them via the computer. The 2008 map updates are currently available, and Garmin has told me new maps will be out in a few months.
Mar 09, 2008 | Garmin StreetPilot c340 GPS Receiver
I cannot even tunr on my brand new fresh out of the box street pilot 340? Any ideas?
there is a red button on the side of the unit, hold that and the unit will come on.
Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
51 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
