Question about Compaq Deskpro EN PC Desktop
Power problem I have a compaq deskpro p3 and the problem is i can't turn it on I have to wait for 5 hours before i can make it on. There is blinking green led in the mother board. How can i solve this problem? It looks like the power supply... what spare parts should i have to replace inside my power supply? i am a electronic technician.
    Novelist:
    Scholar:
  • 134 Answers
Considering you are an electronics technician, you will know this is a loaded question. Your best bet is to swap the power supply with another one (if you have access to another pc) Most modern PC power supplies are the same now, although as they go back in age, there are some differences.. Anyway, best to swap power supplies with a known good one and see if the symptoms change. If it works, then yes, faultfind the power supply.
As you will know, it will be a switched mode supply, therefore dangerous to test in open circuit state.. Be carefull! - As a technician, you will know that you can check some obvious test points, for example the diode bridge and somewhere near the output, where you might expect correct DV volts. A 'CRO' might be handy here as well, but a digital Volt/Ohm meter is OK too.
Try these sites for help:
http://www.daileyint.com/hmdpc/manual.htm
http://www.repairfaq.org/sam/smpsfaq.htm
Remember: Beware of dangerous voltages in switched mode power supplies. They can bite! It may be better to replace the unit.
Posted on Jul 18, 2008
Deskpro en p111 blink red light when powered. pls what is the solutions? phil
for my experience it has a defective procesor but it may be also a drop in the power supply
first try to test with a diferent procesor
May 17, 2011 | Compaq Deskpro EN PC Desktop
How to remove the top cover of compaq deskpro p3?
Press both tabs on the front plastic of the case, and pull in forwards. You can then lift the top off.
To replace, sit on, slightly forwards, and bang backwards with force.
Oct 19, 2010 | Compaq Deskpro EN PC Desktop
My compaq on then goes off and also the power light indicator blinks very fast continously
Its in hibernation mode. Go into control panel / power options and disable all power options.
Jan 12, 2010 | Compaq Deskpro EN PC Desktop
Tried swapping pIII 550 mhz slot one processor for Pentium III P3 1GHz Slot 1 CPU 1000MHz /256/133 SL4BS in deskpro en p550.It wont do anything, screen is blank.Compaq told me i could go as high as...
This isn't a sure fix by any means, but...
You could try unplugging the unit from the wall socket and opening the case. Touch a metal component inside the case for a few seconds to equalize static charge between yourself and your machine.
Next, remove the battery on the motherboard, and wait 5-15 minutes before reinstalling it. What this will accomplish is to reset the computers' BIOS (Basic Input Output System) settings to the defaults for the motherboard, which may let the machine figure out what processor you installed.
If it works, your machine will boot up, and you'll get an error message telling you that there is a checksum error or simply that a BIOS setting is wrong. You'll have to read the message and press the appropriate key to get into BIOS, then reset the date and time.
I hope this helps in some small way- It's rough attempting to set up a machine if you have no visual output to let you know what's going on.
If my solution gets you up and running, please let everyone know by writing a testimonial.
Oct 18, 2009 | Compaq Deskpro EN PC Desktop
Red blinking light when on my compaq deskpro en pc
Probably your power supply. They are pretty cheap to replace. If it's plugged into a power bar then try plugging it directly into a wall socket just to make sure it isn't your power supply.
Apr 01, 2009 | Compaq Deskpro EN 6350 Model 4300...
D845epi Is frozen on Express BIOS Update
hold down the power buttom till the system turn off and wait for some minutes then power back on. this situations happens when you are updating an old bios.
Feb 18, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Compaq Deskpro-P3 : While Starting Compaq Logo Appears,red light
its may ur cmos battery problem u can replace ur cmos battery and check that prolem
Jan 29, 2009 | Compaq Deskpro EN FC 6450+ Model 10000...
Compaq Deskpro - video problem?
i got ur answer that is once remove the ram and clean it and keep again. Maximum it works other wise check the load is comg frm smps or not 5v to mother board r not
Jan 12, 2009 | Dell Optiplex GX280 (99301) Motherboard
My Compaq Deskpro wont power up.
check the capacitors in mother board, if it is bulged replace it. it will work als check the same in ATX power pack.
Dec 24, 2008 | Compaq Deskpro EN 6350 Model 4300...
Compaq Deskpro EN PC Desktop Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
